replacement 2 piston caliper?
Old Jun 30, 2001 | 01:46 PM
Camaroman's Avatar
I have an '84 Z28 4 wheel disc...
is there such a replacement caliper?
or do you have to do the whole upgrade (1LE)?
Old Jun 30, 2001 | 02:53 PM
Jason M 91Z's Avatar
No such item exists. Also, I don't feel that a twin piston caliper would make any improvement in pedal feel or fade. The inherent problem in using little rotors in big cars is that modulation becomes difficult and inconsistent. I bet that if our cars came with 1LE sized rotors and the same cast iron stock single piston calipers, our brakes would be pretty good. I just did the 1LE upgrade, and put in a 97 T/A rear end w/ 11.625 rotors, and it stops like an animal now. There really is no cheap solution to upgrading the caliper or rotor.
-Jason M. 1991 Camaro Z28
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
BBSDesigns
Aug 11, 2015 07:39 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
