Anyone have an opinion on my front tire camber problem?
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
Hey all. Crashed my car into a curb a while back, and paid to have the frame bent back.
Well, i noticed the camber was very positive on the front passenger tire, so i took it to a shop, and they just set the camber as far negative as they could. It is still bent inward at the bottom of the tire.
I was told by the mechanic that i would need an entire new front suspention, i.e. idler arm, pitman arm, centerlink, tie rods, and steering knuckle.
This mechanic also ripped me off with repairs, and i was told by another shop in the area that they were big ripp-off artists. Does anyone else have any idea why i would need to replace all of that? wouldn't it just be the steering knuckle? I have no clue myself, even went under the car to look, compaired sides, looked fine to me. but then im not a mechanic either of course.
Any opinions would be great!
1986 IROC Camaro
305 TPI "LB9"
3.23 gears
Doesn't know enough about cars.
AIM: jesusathome
1986 IROC Camaro
305 TPI "LB9"
3.23 gears
AIM: jesusathome
Hopefully they pulled the frame right. Look at the lower control arm and see if you can tell if its bent. Steering parts have nothing to do with the camber unless its bent so bad the tires won't align. For posotive camber look for a bent control arm or spindle.
The control arm is new, well not new, but the mechanic replaced the one i had with a used one.
The spindle? time to whip out the chiltons like i know what im doing...
1986 IROC Camaro
305 TPI "LB9"
3.23 gears
AIM: jesusathome
1986 IROC Camaro
305 TPI "LB9"
3.23 gears
AIM: jesusathome
Car: 82 camaro SC
The frame shop didn't correct/fix the front end? I would be upset. A good frame shop will be able to straighten the unibody and fix the front end problem--they can tell what is bent when it's hooked up to the equipment. Could be the spindle, front subframe, strut, etc... The steering stuff(idler arm and such) has no effect on camber. Spindles don't usually wear out--junkyard time.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
82camaro
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
