How many torque arm mount styles are there for the T5?
Old Sep 7, 2010 | 12:54 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I am trying to get my torque arm mount working with my T5. The mount didn't come on the tranny, I got it from another T5 in the junkyard. I have the "lips facing out" torque arm, but my Energy Susp. bushing simply will not fit inside it.
My understanding was that there were 2 designs of bushings; one with lips facing in, the other with the lips facing out.... but are there multiple T5 torque arm mounts? I thought the mount itself was the same but the bushing could be either or, depending upon which torque arm mount you had.... Is this correct or do I have to switch to the "lips facing in" torque arm and get a "lips facing in" bushing??
HELP!
Old Sep 7, 2010 | 02:41 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: How many torque arm mount styles are there for the T5?
Originally Posted by Dante93GTZ
I thought the mount itself was the same but the bushing could be either or....
That's my understanding for 84-92; however, the 82-83 models, IIRC, are different. The following links might prove useful:
https://www.thirdgen.org/forums/tran...g-problem.html
https://www.thirdgen.org/forums/tech...allations.html
JamesC
Old Sep 7, 2010 | 03:53 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
JamesC
The first link shows in pictures the EXACT same problem I'm having with my T/A mount, but unfortunately the 5 year old post had no resolution.....
Old Sep 7, 2010 | 04:27 PM
JamesC's Avatar
According to the other post, you have the mount from an 85--same year as my IROC. I'm using 84-92 Torque Arm Mount Bushing (Lips facing away from driveshaft (Jeg's 355-3-1111R). Fits fine.
JamesC
Old Sep 7, 2010 | 05:27 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
It just doesn't fit at all; it does this:
It seems no amount of clamping it down results in a proper fit - It fits just fine in the auto mount though.
Old Sep 8, 2010 | 09:39 AM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
We "fixed" it by taking a dye grinder to the bushing and filing down the part that wasn't fitting. Its still a snug fit, but it'll work just fine...
deracer
Apr 11, 2016 12:04 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
zayne0
Aug 24, 2015 07:22 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
