torque arm bushing problem
Old Nov 24, 2005 | 07:56 AM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
Ok, here I am in Japan, with a brand new torque arm bushing that will not fit in the MANUAL MOUNT BRACKET. It works great in the AUTO bracket, but will not fit in the 5 speed one. The P/N is ENS-3-1111G. Summit said it should fit. The mount i believe came from a 1991 car. I takes 7-10 days to get parts over here, so this is the last thing i need!
Any ideas? Were the mounts different or just the "rubber inserts?" Here are some pics to help.
Thans to all, and have a HAPPY TURKEY DAY.
SHAWN
Old Nov 24, 2005 | 07:57 AM
auto mount with bushing
Old Nov 24, 2005 | 07:58 AM
manual mount with bushing . Crushing does not work.
Old Nov 24, 2005 | 07:59 AM
manual mount
Old Nov 26, 2005 | 02:15 AM
OOF , Another of my "impossible" questions. They seem to get 30+ looks, and no responses.
Old Nov 28, 2005 | 12:10 PM
DanS's Avatar
I had the same problem on a manual mount, but eventually got it to fit. First problem was that I didn't get the old rivots fully ground off. After taking care of that I eventually got the clamp to close, but it took using a C-Clamp to compress it while installing the bolt. It was a real pita, but it worked.
I hope this helps.
Old Nov 28, 2005 | 06:51 PM
morpwral's Avatar
Car: 82 Firebird SE
Engine: 350 CCC 4bbl
Axle/Gears: 10 Bolt, 3.23
Am I assuming correct that you are trying to set up a manual trans? The part # you posted is for a torque arm with the lips pointing away from the driveshaft. Did you get this bushing in factory Energy Suspension packing (skinned packed or boxed)? The orientation of the internal slot in the first two pictures is what you are looking for with that number bushing. It should also match your current torque arm setup as well. Does either mount bolt up to your transmission without needing extra parts like spacers and such? The bottom two pictures of the same mount looks as if we are looking at the front side of the mount as it would be mounted on the trans and looking down the driver side of the trans from the front of the car. The stud should be in the bottom rear hole of the trans and the open eared end should be in front bottom hole. The third is the clamshell hole which ties the outer clamshell to the mount and threads into the trans. In the middle pic, do you try rotating the bushing 180 degrees front to back to see if it would fit better?
I'm stating the above because I have a '82 Firebird that is converted from 4 spd to 5 spd and when I installed the poly TA mount, it looks to be the same as your bushing. I did buy the bushing off E-Bay (used) and the only number on it was "1040" stamped on one end where the torque arm would slide thru. I do not remember which end it is actually on in it's current setup. The outer shell on the bottom two pics is shaped closely like the 4 spd's outer shell that was on mine but mine is bolted in from the bottom side with two bolts.
My other setup is a '95 TA 6spd and it uses the same number bushing. Both of my current torque arm setups are the same, lips pointing away from driveshaft.
According to the Jeg's book, #3-1111G is 1984-96, lips pointing away from driveshaft and #3-1112G is 1984-92, lips pointing towards the driveshaft. The 1982-83 mount is totally different and lips point towards driveshaft, 33-1110G.
I have some pics of the '82 with the 5 spd and factory 5 spd TA bushing installed but no pics of the poly one. Also have pics of the 4 spd TA mount and shell as it is bolted to the trans and its poly bushing ot the end of the TA If you'd like to compare. I have no clear pics of the '95s bushing as the x-brace blocks most of the mount. The pics are over 390KB Jpeg each so don't think they will fit here, could e-mail them to you if possible if you like. Let me know.
I hope this helps you out some, Allan.
Old Sep 7, 2010 | 03:51 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Re: torque arm bushing problem
So what ever came of your T5 swap?
I'm swapping a T5 in and have exactly the same problem shown in the pics; how do I fix it? My T5 mount is from an '85 T5.
Old Sep 7, 2010 | 04:25 PM
Crazy to get a hit this far in the future. Unfortunately I don't remember what I did. If I had to guess it would be that i just pinched down that part number really hard and made it work. Sorry, but best wishes.
shawn
Old Sep 7, 2010 | 06:22 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
shawn
If you remember, please let me know - I am in exactly the same predicament you were with the torque arm mount and I _need_ to get this trans swap completed.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
