Transgo a no go....
Old Jul 18, 2010 | 09:07 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
Transgo a no go....
SO I installed transgo shift kit in my 91 700r4 about a month or two ago. First night out with the car after the motor swap and I have no 2nd gear. Anyone run into an problems with the transgo kit? I followed the direction, double and tripple checked everything. The trans was shifting fine before the install. Even installed a new seperator plate also. I'm really at a loss here. I also install a .500 boost valve, WOT 4th valve, corvette servos and accumulators.
Thanks in advance
Rob...
Old Jul 18, 2010 | 09:20 PM
watson90z's Avatar
Car: 1990 iroc-z
Engine: 350 tpi
Axle/Gears: 3.23 posi
Re: Transgo a no go....
had the same problem with my transgo when i had my tranny rebuilt. just sit in the car with the motor off and put the gas to the floor like 15 times. Its a sticky throttle valve in the tranny hope this helps
Old Jul 18, 2010 | 09:21 PM
fiream's Avatar
Engine: 400HP 350
worth a shot....
Old Jul 18, 2010 | 09:39 PM
fiream's Avatar
Engine: 400HP 350
nope, that didnt work... I even readjusted the TV cable
Old Jul 19, 2010 | 08:38 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Check the 2/4 servo stack up. Passenger side of tranny. This is what applies the band for 2nd gr (along with 4th gear).
RBob.
Old Jul 19, 2010 | 06:41 PM
fiream's Avatar
Engine: 400HP 350
RBob.
Spent all day doing that. tried multiple different shim stacks and I still have no second. Now I dont know what to do...
Old Sep 7, 2010 | 08:31 PM
fiream's Avatar
Engine: 400HP 350
SO I took the trans apart today. A few things I notice. The servo pin was has a bright shinny tip on it. its not black anymore..lol Second thing is, that when I dropped the VB the band anchor fell out at the same time. When I looked at the band again, I noticed that the band has slid foreward. The band is hanging about a 1/16" off the front of the drum twards the front pump. So how do I fix this? Do I have to drop the trans out of the car?
italiano67
Sep 22, 2015 08:42 AM
crazynights
Aug 21, 2015 06:53 AM
ONEFORMULAOVERALL
Dec 18, 2001 03:13 PM
curt86iroc
Carburetors
Dec 12, 2001 08:58 AM
FasNuf91
Aug 22, 2001 11:20 PM
