STILL PULLING TO RIGHT HELP ME!!!!!
Old Jul 19, 2001 | 03:37 PM
STUB25's Avatar
I have replaced everything in my entire braking system including the rube hoses to the calipers and my car still pulls to the right under braking!! This is so $*#!!*& anyoying. Some one helpe me I don't know what is next.
Old Jul 19, 2001 | 03:40 PM
Camaroman's Avatar
Do you have rear drums?
my friends dad had a bad drum in the front of his dodge dart and it would tear the wheel right out of his hand...
new drum....no problem.
if you do have rear drums try swapping drums from side to side and see if the problem swaps sides.
Old Jul 19, 2001 | 04:16 PM
STUB25's Avatar
It's not coming from the rear at all. When it pulls it feels like it is diving into a corner. Also I have been having this strange fluid leaking out(just a little) on to my wheel, does anyone know what that is from?
Old Jul 19, 2001 | 05:02 PM
ATOMonkey's Avatar
You're right the rear is not making the car steer to the right. The brakes on your car aren't designed very well and are very particular about how they are mounted, and the mounting hardware. My car did and still does do the same thing, only not as bad. The allen bolts that hold the caliper to the spindle have a tendency to flex causing the caliper to bind, or not contact properly. Replace the Allen bolts with new ones, and make sure the rubber o rings in the caliper where the bushings for the bolts are aren't binding on the bushings. The bushings should go in real easy without any pushing at all. If you had to install the bushings with a hammer, then the caliper can't float the way it's supposed to. Some lithium grease around the bushing really helps. If I can ever fix this problem completely I'll probably write a paper about it, because it is very frustrating.
'89 Red Formula 350- 350 .060 over forged pistons 232* @ .020 cam Performer RPM Holley 750 DP Vortec 1.94 1.50 Accel Coil and dist. Hedman shorty headers Dual Exhaust w/ cutouts 1LE WS6 suspension, wheels, and brakes, 9 Bolt 3.27 Posi Edelbrock LCA's & Track bar subframe connectors 700R4 Harwood snorkel scoop Eclipse Head Unit Delco Bose Speakers 2 12" Pioneer subs w/ 400 watt/chanel amp
Old Jul 21, 2001 | 10:12 PM
82camaro's Avatar
Car: 82 camaro SC
That leaking fluid will make it grab. Find and fix the leak.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
wigmobile
Feb 26, 2025 02:56 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Amillionoh7
Sep 11, 2015 11:36 AM
sylentnite
Sep 9, 2015 02:55 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
