Installing shocks and struts
Old Jul 23, 2001 | 07:11 PM
ADMZ24's Avatar
Car: 1991 Trans Am
I have KYB shocks and struts on the way and when they arrive, can I install them myself? If so, what do i need..what kind of tips can you give me about installation?? Any help is welcome. Thanks
1991 WS6 Trans Am
Medium Green Metallic
Beechwood interior
305 TPI
TH 700-R4, Auto
T-Tops, PW, PL, PM
Keyless entry, alarm
Flowmaster Muffler
Monza Dual Tips
K&N Filter
Macewen white faced overlays with Xenon bulbs
Old Jul 23, 2001 | 08:31 PM
robbob's Avatar
If you're good with cars you could do them yourself,just get a haynes manual or other similar book.
You could probably get them installed pretty cheap at Midas or some other shop if you're not comfortable doing it yourself,I know I wasn't.
Old Jul 23, 2001 | 08:35 PM
ADMZ24's Avatar
Car: 1991 Trans Am
I have a Haynes manual and it doesnt sound too difficult.
Old Jul 23, 2001 | 08:46 PM
Hulk0202's Avatar
Its not very hard at all. The back is real easy and the front wont require that much more effort. Just make sure you have support under the wheels so the springs stay compressed.
Old Jul 26, 2001 | 11:44 AM
88 Camaro SC's Avatar
Car: 99 Trans Am
<font face="Verdana, Arial" size="2">Originally posted by Hulk0202:
Its not very hard at all. The back is real easy and the front wont require that much more effort. Just make sure you have support under the wheels so the springs stay compressed.</font>
Not hard? I went to a Meinke to ge an estimate: $250 for front and back. Supposedly with the back, you need to take out the rear seat to get to some of the bolts or something. Is this true?
Nate
1988 Camaro Sport Coupe
  • Custom Interior
  • K&N Air Filter
  • Custom Ram Air
  • 180* Stat
  • Shift Improver Kit
Homepage: www.rsdragster.cz28.com
Old Jul 26, 2001 | 02:51 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You -can- take out the rear seat, it's not required, but it's easy enough. Just remove the folding seatback. There's a 10mm nut in each lower side corner. After that's out, pull the carpet up along the back. The upper shock nuts are right where the "***** " of the car meets the "flat spot" under the window, in the corners of the car. They're underneath pieces of yellow foam. Torque for those is light; IIRC only 15 ft/lbs.
If that was just a labor quote from Meinke, that's a lot of dough- especially considering they have a lift for easier access. Now, if that included parts & labor & a front-end alignment (which you should get after new front struts), that's a good price.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jul 26, 2001 | 02:59 PM
ADMZ24's Avatar
Car: 1991 Trans Am
Just finished installing the rear shocks. The lower bolt was a pain, but once it broke loose, the rest was a breeze. It took about an hour. I dont have time to do the struts tonight, i have to work. But I will try to do them tommorow. I will be sure to make sure I can get an alignment before the weekend though.
Old Jul 26, 2001 | 07:48 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I did mine myself and it was pretty easy. Time consuming, but easy.
One piece of advice I give to everyone is to use a Clench Wrench from Sears to hold the top of the strut pins still, so you can remove the nut. I tried a pair of Vise Grips on the first side, and knawed it all to hell. Then it hit me like a ton of bricks. The second one was SOOO much easier with that Clench Wrench.
You gotta use the smallest wrench though. The second size up is too big. It won't "clench" onto the metal. If you've looked under the covers on the bracket, then you've seen what I'm talking about. The thing has two sides, and rounded sides between them. Other people on here say they've used Vise Grips with no problem, so maybe I just had bad luck, but who knows.
Good luck.
AJ
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
1992 Trans Am
Aug 9, 2015 04:32 PM
