No trailer hitch install with dual exhaust?
Old Sep 12, 2010 | 10:40 AM
bonezz's Avatar
I need to put a hitch on my 89 iroc 5.7 to trailer my motorcycle. I found the hitch but it says it cant go on camaros with dual exhaust..anyone know about this, if its true or if it be worked to actually go on?
Old Sep 12, 2010 | 10:54 AM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Re: No trailer hitch install with dual exhaust?
Uhhhh buy a truck?
Old Sep 12, 2010 | 11:19 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Mine had a hitch and also had stock style dual exhaust...
if you are close to eastern Iowa i'll give you a really good deal on one, i even have the wiring harness. Not something that i'd want to ship though, it's pretty heavy.
Old Sep 12, 2010 | 12:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
no 3rd gen had dual exhaust, all had 2 tips though, i dont see why it would affect the hitch.
Old Sep 12, 2010 | 12:40 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Some early models (82-85 LG4/LU5) did have an exhaust with two mufflers and a tip per muffler.
JamesC
Old Sep 12, 2010 | 03:41 PM
Typical trailer hitches for these cars bolt to the inside of the "frame" rails right in front of the bumper.
Look at that spot; you will notice that your exhaust goes right there, and there's a hanger at that place, as well. Assuming your car is well maintained and doesn't have some hilljack "improvements" back there.
You will need to relocate the exh tip on that side a little bit. It has to move out an inch or 2. Not too noticeable, unless you look REAL close and know what you're looking for, that the exit point of the tips isn't quite exactly the same.
Old Sep 12, 2010 | 08:03 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Originally Posted by shortyskater
Uhhhh buy a truck?
My 3rd gen ain't haulin' nuttin' but @ss!
Old Sep 16, 2010 | 09:42 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
So that was why the PO of my car welded the driver's side pipe on at a different angle than the other! Idiot!
Seriously, though. If you're going to put a hitch on, it may rub against the lower part of the bumper. Don't do like my PO did and CUT notches into the bumper. And don't half-bake the wiring so bad it can just be pulled out...
Old Feb 8, 2013 | 07:54 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
My trans am came with a hitch
Old Feb 21, 2013 | 12:57 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Do a search for my Ultimate Trailer Hitch thread, I still have this massively-overkill monster. Nobody here wanted to buy it. But it'll clear ANY exhaust system. Buy mine or build your own copy.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
onefreakz
May 14, 2018 12:15 PM
drathaar907
Aug 6, 2015 04:20 PM
