SFC cutting for exshaust clearance
Old Jul 9, 2001 | 12:00 PM
FloridaRacer's Avatar
does anyone have an pictures of how much you cut off the subframe connector?
and do you think structural rigidity was compromised in any way?
does anyone know of a ypipe/sfc combo that is truely a plug and play deal with no cutting involved?
Thanks,
Mike
FloridaRacer.com
Old Jul 9, 2001 | 01:45 PM
86Trans Am's Avatar
i have slp's and spohn sfc's, i had to cut about 6 inches off the the passenger side connector, and steve said that would be alright
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
Old Jul 9, 2001 | 03:38 PM
well, id rather not cut any off the frame... ill be using this car for SCCA road racing and frame rigidity is very important.
FloridaRacer.com
Old Jul 9, 2001 | 10:45 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
I want to do the same thing with my hotchkis SFCs (shorten the right side and weld it to the floor pan next to the cat) this may compromise how the SFCs help the car,but the "rigidity" of the shortened SFC should be the same,as long as it's cut and re-welded properly. the left one would be in solid and the right would be mounted in the rear where it should be,but 12" back from where it's supposed to be in the front. this shouldn't compromise too much,unless the shorter end is welded to a weaker part of the unibody than it would be if it was wher it was desighned to be. technically,the frame connector itself would be more rigid if it was shorter,but by the looks of these Hotchkis peices,I doubt they flex very much at full length.
Old Jul 29, 2001 | 10:14 PM
812MANY's Avatar
Hey Florida Racer, I just made my own SFCs Saturday. I used 1X2X.110 CR1018 along the pinchwelds. I just bent the Y-pipe a little.
Are you going for A Sedan? If so you should run longtubes, then you shouldn't have any problems with SFC clearance.
I'm in Pines.
Email me @ J812MANY@aol.com and we'll talk.
Old Jul 29, 2001 | 11:41 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Sorry no pics.
I have my SFC put in when the car still had a single 3" exhaust system on it. The SFC were custom made and they just sectioned the SFC to go below the pipe.
Now there's no exhaust system but the SFC section is still there and as strong as ever. It just looks a little funny when you look under the car and the passenger side SFC has a jog in it instead of going straight back. The SFC are made out of 2 x 2 x 3/16" square steel pipe.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
skinny z
Oct 5, 2015 06:23 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
