What do u keep your tire air pressure at??
Old Jul 26, 2001 | 06:35 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
What do u keep it at, more in fronts or more in rears??
89 RS
STILL Looking For:
87 IROC-Z28 350 TPI
Old Jul 26, 2001 | 07:36 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Um, well, uh see, I just, well I, I dunno.
I run mine 1 psi more in the front than the rear, (31/32) but I probably don't have to. The main reason I do is to compensate for the slight amount of weight bias that the engine has on the front end.
Plus the down force on the front end from aerodynamics.
Plus the weight transfer to the front wheels when you apply the brakes.
Plus the quicker response you get from the steering wheel.
Plus the cornering forces are greater on the front tires.
Plus running slightly lower pressures in the rear tires can USUALLY (not always) increase traction and acceleration.
There is probably a lot of testing that's been done, but the findings may not have a good effort-to-results ratio.
Plus I may be talking out my a$$. I could be totally wrong. I've never owned a car long enough to see what kind of wear patterns the tires had after running them that way. I average a car a year.
Old Jul 26, 2001 | 08:33 PM
nicmike85's Avatar
I run mine at 30psi and I get the correct tire wear. For a 245/50ZR16. This also seems to be the ideal tire pressure for performance.
Old Jul 26, 2001 | 11:36 PM
R.O.B.'s Avatar
I use 35psi front, 30psi rear on 235/50 R16 tires.
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
Old Jul 27, 2001 | 06:29 AM
Norm Peterson's Avatar
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
34 front / 29-30 rear with 245/50-15's on 15x8.5 rims on the Malibu (see sig). Tire wear is even with about 1/2* negative camber. I still corner it hard whenever the opportunity presents itself.
Norm
1979 Malibu w/some cornering tweaks and a few other interesting things
Old Jul 27, 2001 | 09:19 AM
Spyder's Avatar
I run 37PSI in the front and 40PSI in the rear, the max PSI for my tires though is 52psi.
Old Jul 29, 2001 | 08:48 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
I put 36 all around. But when I SCCA race. I up all of them to 45. And when I drag race. I put 50 in the front and 30 or less in the back.
Chris
91 RS 305 TBI
Eternal Rev
Possibly one of the worlds only drifting Camaros!
Old Jul 30, 2001 | 01:16 AM
Administrator
Whats better for street and drag racing, more in front or more in rear??
89 RS
STILL Looking For:
87 IROC-Z28 350 TPI
Old Aug 3, 2001 | 02:27 AM
silver89Rs's Avatar
on the street i run 34psi in the front and 36psi in the rear on the track i run 60 psi in the front and 22-27psi in the rear. that is with slicks and front runners.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
Dialed_In
Aug 20, 2015 01:45 PM
jackhammer
Aug 15, 2015 10:04 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
