replacing front LCA bushings.....do i have to install the LCA in a certain position??
Old Aug 1, 2001 | 07:36 PM
CamaroZ_85's Avatar
friday i'm replacing the front susp. on my car...struts, springs, ball joints, LCA bushings etc. i was reading a haynes or chiltons a while back and it mentioned something about measuring the location of the LCA bolts in relationship to the ground so you can reinstall the LCA in the same position. is this true, or a pile of crap? i would think that if the LCA position was adjustable, then it would be floppin all over when you hit bumps, even w/ tight bolts. thanks for any info
85 Z28- 350, Comp 262, Edelbrock Performer intake, Edelbrock 600 cfm carb and Edelbrock cat back, Summit headers and vette servo
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
Old Aug 1, 2001 | 08:19 PM
Hulk0202's Avatar
I rebuilt my whole front end and didnt encounter any type of adjustment or movement where they bolt up. It can only go in one way I believe.
Old Aug 1, 2001 | 08:45 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Probably what you read was about the idler arm height, usually referenced by the relay rod which has a flat spot on it right by the front LCA bolt. The trick usually used is to place a socket on that bolt and measure the distance between the socket and the flat spot at the pitman arm FIRST, and then do the same for the idler arm, using the same dimension...
KAM
Old Aug 4, 2001 | 06:47 PM
CamaroZ_85's Avatar
nah i'm sure i read it about the LCA cause i double checked and found it again. it said to torque the LCA bolts at "Z curb hight" in the chiltons, and haynes said to torque them with the wheels on the ground, whatever. but the idler arm thing i've been wondering about forever, cause i replaced it and didnt set it up right for some dumb reason, so thanks a lot for the help!!
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
TheExaminer
Aug 25, 2015 07:34 PM
wruiz
Aug 11, 2015 02:59 PM
NBrehm
Aug 5, 2015 07:57 PM
