do you have to align the front end when putting on new tires?
Old Aug 8, 2001 | 11:26 PM
matthew's Avatar
I am going from 215/65R15 to 255/45ZR17 tires and wheels. Would my front end need to be aligned afterwards or would I be ok with out one?
yellow 86 Camaro
LG4 700R4
Pioneer head unit
Kenwood speakers
Infinity Beta Digital 300 amp
2 Infinity Perfect 12s
Now KYB equipped!!
Old Aug 9, 2001 | 08:59 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You don't have to; but after spending all that money, don't you want (A) those tires to last as long as possible, and (B) your best ride possible?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Aug 9, 2001 | 09:04 AM
82camaro's Avatar
Car: 82 camaro SC
When changing wheel size, I would get an alignment set-up for the lower profile tires. If it hasn't been done it a year, it probably needs aligned anyway.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Aug 9, 2001 | 10:16 AM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
it depends,did the front tires you replaced have equal wear......if they did most likely you won't need to have it alighned,but at the same time like 82camaro said if its been a while since you had one it's suggested....
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
bellez77
Sep 5, 2015 08:39 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
Leggman1
Aug 6, 2015 04:15 AM
