Best engine and tranny mounts?
Old Aug 7, 2001 | 01:27 AM
L98FORM89's Avatar
Car: 1989 Formula 350
Engine: 355 HSR
Transmission: Rossler 700R4
Axle/Gears: 9 bolt/3.27
Any suggestions?
89 formula 350, 73000k, 9-bolt 3.27, gutted MAF,dynomax muffler,gutted air box,kn,accel 8.8 coil wires,dunlop 60/235
g-tech best(9 runs)14.48@101.1(G-tech records actual speed at 1/4 mile not a true "trap speed" 0-60=5.91
track best(3 runs muncie,in 88 degrees)14.51@96.0 60' 2.089(I later found out I had 2 bad injectors and 2-3 gear was going bad)
in the garage waiting to go in are alum. L98 heads(bowl job by scoggins-dickey),ported high-flo edelbrock base,SLP runners, Jethot coated SLP 1 5/8 headers,ZZ4 cam 208/221 .474/510,1LE alum. driveshaft,LPE feul reg.,TPIS air foil,block bored .030 over,decked,balaced,ARP main studs,Flowmaster ForceII cat back,Gold crane 1.5 rollers,Eagle forged 5.7 rods, Speed-Pro forged -21cc dish pistons,ACT 9 1/2 in. 2500 stall converter,MSD 6AL,8.5 wires,BlasterII coil,lots of ARP bolts,
Old Aug 7, 2001 | 02:53 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Energy Suspension.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Aug 7, 2001 | 11:47 AM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
I second the Energy Suspension. They are the best I know of.
Old Aug 7, 2001 | 12:50 PM
JPrevost's Avatar
Car: 91 Red Sled
Except for the fact that they don't have 36mm front sway bar bushings. They do have great tranny and engine mounts though.
, Jon (350 TBI!)
91 Red My website
Old Aug 8, 2001 | 04:45 AM
Omar's Avatar
I'll 4th the ES also.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Aug 10, 2001 | 01:05 AM
twistedwedge's Avatar
Car: 87 GTA
Engine: 355 Chevy
got both motor mounts and a tranny mount on my car all ES...love em.
1987 GTA 355 inch motor, carbureted, TFS 23* heads, T-56 6-speed, McLeod clutch, 11.3:1, Lunati hydraulic roller .510/.525 lift 232/242 duration @.050 on a 112* lobe seperation, Hooker super comps, Dual 3" flowmaster 2-chamber exhaust with NO tailpipes, 98 Z-28 wheels, Strange 12-bolt rear w/4.30 gears, 33 spline axles and a spool.
This car is driven on average 100 miles weekly... ...Whatever turns your tires.....
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
timonator
Aug 11, 2015 09:56 PM
Elliswon
Aug 10, 2015 12:33 PM
