Brake Problems
Old Aug 6, 2001 | 01:58 PM
RSRagtop's Avatar
Brake Problems
A couple of nights go on my way home I tried to race a Grand National ( with a stock 305, foolish I know ) but when I tapped the brakes to slow down the car pulled hard to the drivers side momentarilly. The car also shudders when I slow down sometimes. I thought it was because of my wasted drag link but I replaced it and it didn't stop the problem. Are my calipers sticking? Warped Rotor?
Old Aug 6, 2001 | 03:05 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
I would almost bet the shuddering is a warped rotor. Did you get on the binders hard when it pulled or was it just normal braking?
Old Aug 6, 2001 | 08:08 PM
RSRagtop's Avatar
Normal Braking
Old Aug 11, 2001 | 01:34 AM
84berlinettaV6's Avatar
I had the same problem with my car but it veered left everytime i braked. It turned out that my front right caliper was seized. It also sounds like your rotors need machined. My caliper also seemed to stick at stop signs until i gave it a little gas.
Take it to Midas and they should look at your brakes for free and tell you what's wrong with them.
Old Aug 13, 2001 | 12:04 PM
IROCZ89's Avatar
Car pulling could be many things, caliper locked as stated previously, proportioning valve, clogged brake line, etc. The shuddering sounds like rotors that need to be machined.
Just a side note: I have not had good experiences with Midas, they tried to tell me that there was more wrong with a car than what really was. Find a good mechanic and have them check it. Or if you have a friend that is good with brakes have him take a look at it.
Just my .02.
Phil
Old Aug 13, 2001 | 03:26 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well, i had the same problem and i rebuilt both brake calipers ect,ect, but the cure was to replace both front flexable brake lines. Don't get them mixed up as there is a left and a right. Good Luck.
-Auggie-
Old Aug 13, 2001 | 05:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You can't really mix them up, the brackets are keyed.
Old Aug 13, 2001 | 10:39 PM
Auggie's Avatar
Yeah, I know Apeiron but you know how it goes sometimes.
-Auggie-
Old Aug 14, 2001 | 12:18 AM
RSRagtop's Avatar
Thanks for the info. I just pulled my master cylinder top and found that my brake fluid is now "chocolate milk", so I will be flushing the system and checking all of the areas you suggested. Thanks again for the help.
Old Aug 14, 2001 | 12:54 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
<font face="Verdana, Arial" size="2">Originally posted by Auggie:
Yeah, I know Apeiron but you know how it goes sometimes.</font>
Yeah, as long as you know they're keyed and don't try to make them fit.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
overdriv
Aug 20, 2015 03:52 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
