tubular LCA bushing?
Old Sep 27, 2010 | 07:43 PM
ThEWhitebirD's Avatar
Car: 1989 Pontiac Firebird
Engine: 305 Tbi w/lt4 hot cam
Axle/Gears: torsen 3.42
I've had the umi lower control arms with poly ends for over 5 years now.. love them but I noticed the bushing on the driver side was cracked and a chunk came off... so I need new ones. a bunch of companys say they use energy suspension bushing but I cant find the part number.. anyone know it?
Old Sep 27, 2010 | 07:47 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: tubular LCA bushing?
if its from emergy suspension, it would be a universal sized bushing, you would have to get dimensions and go from there.
or possibly call UMI and order replacements?
Old Sep 27, 2010 | 08:16 PM
I had searched the boards but no luck.. I figured someone has replaced them in the past and there would be a part # floating around to throw into summit racing and order them, but that would be to easy...
Your right though, I just checked the energy suspension pdf catalog and they show them as universal but theres a few different ones I don't know the measurements..
Ill save myself some trouble and call umi tomorrow..
Old Aug 4, 2022 | 12:18 PM
raptere's Avatar
Car: 1991 Camaro Z-28 (Durango R/T)
Engine: 383 L98 W/ HSR
Transmission: 700R4 Tuned Shift 2600 Stall
Axle/Gears: 3.73 10Bolt Posi W/ Al Cover, Disks
I know its been a long time, but others may be looking too, like I've been. I'm searching for the same thing but for Lakewood LCA's.
This may be what you are looking for if your old bushings are stamped with 2142 on the inside...
Control Arm Bushing 2142 - UMI Performance Inc.
My additional research can be found here: Modifying poly rear LCA bushings to allow slightly more articulation? - Third Generation F-Body Message Boards
LarryD
Sep 24, 2013 10:19 PM
AMAXRX
Jan 9, 2013 05:19 PM
Yonash91RS
Dec 31, 2007 11:25 AM
1988-305-tbi
Oct 16, 2006 06:10 AM
ta84-355
Mar 20, 2002 10:46 AM
