CAN ANYONE IDENTIFY THEESE BUSHINGS
Old Oct 15, 2006 | 10:51 PM
1988-305-tbi's Avatar
i bought the energy suspension hyperflex master bushing kit for the 82-92 camaro. i have installed all the other bushings but theese... the kit came with the front a-rm bushings, 4 total, the rear lower control arm bushings, 4 total, panhard bushings, 2 total and 4 dust boots, and these other bushings 2 marked "1037" and 2 marked "1038" with what i beleive is two metal sleeves to connect them and allow for a bolt to run through them. i installed the front a-arm bushings, and the rear panhard/lower crontrol arm bushings but now i have these left over, i really hope some one knows what there for and where they go, because i don't.
i was reading a post about the hyperflex master kit, and i seem to agree with what i read, most people said it's not worth the money, and i have to agree the front a-arm bushings are the only ones you really should buy. i installed the new poly-urethane bushings in the panhard/lower control arms and was satisfied with the bushings , but the factory stamped sheet metal is so flexable i ended up buying tubular control arms/ panhard bar with the urethan bushings, for about the same cost as the whole kit, so wait to get tubular/adjustable rear control arms and panhard bar, just go with the front a-arm bushings, which buy the way tightned up thre front a lot. any how heres some pictures of the mystery bushings, so if anyone knows where they go please tell me! thanks for reading my posts -Scott-
Old Oct 16, 2006 | 12:27 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
That's weird, almost looks like a end link donut, but with a very short sleeve.
1982-92 HYPER-FLEX SYSTEM Complete Master Bushing Set Includes: Front and rear control arm bushings, front end link set, rear panhard bar bushings and tie rod end boots.
You didn't list that you did the end links, so... This them?
Funny you say the front a-arms did the most. I've done all poly except for the front a-arms, and i'm going to do them very soon. Hope it gives the results you say!
Old Oct 16, 2006 | 12:34 AM
yes i've also done the endlinks, which are about 1/2 the diameter of theese bushings, with the old a-arm bushings you could easily twist the arms side to side, with the poly bushings they only move up and down like theyre supposed to
Old Oct 16, 2006 | 01:08 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Those are secondary transmission crossmember bushings. You don't necessarily have a secondary transmission crossmember, though.
Old Oct 16, 2006 | 01:31 AM
there we go ....thanks Apeiron, which cars had the secondary transmisision crossmember, my car is and 88, was it maybe used on older camaros? i've taken out the transmission, 700r4,and i have one crossmember, with no bushings applicable, yet another reason not to buy the hyperflex master kit, parts you don't need. thanks again, i kinda thought it might be something extra
Old Oct 16, 2006 | 05:23 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
So it's a Energy Suspension Transmission Crossmember Bushings: ENS-3-1109G - summitracing.com. I too, would like to know what car would use such a bushing?
Old Oct 16, 2006 | 05:44 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
This may help, though I'm not entirely sure there's a definitive answer:
https://www.thirdgen.org/forums/hist...ss-member.html
I have brand new, in the bag, GM rubber bushing should anyone be interested (cost and shipping). By the way, torque the poly to spec or you'll experience an unpleasant harmonic sound/vibration.
JamesC
Old Oct 16, 2006 | 06:10 AM
Jade Grey's Avatar
Engine: 305TPI
Adequate answer and that attached picture from your old post really helped explain it, James. Early cars that had a secondary transmission crossmember used it. Generally, these were manual transmission cars.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
camaro1185
Oct 26, 2015 06:51 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
