How to make a car hook perfect
Car: 1991 Camaro Z28
With the use of street legal tires.
Talking under 350 hp
Possible? And still be a daily driver with some comfort?
Just list the pieces needed please, don't have to go into any great detail unless you wish.
91 Z28
Best Time Slip:
60' - 2.098
1/8 - 9.137 , MPH - 76.21
1/4 - 14.213, MPH - 97.55
Performace Mods: SLP Exhaust
Appearance Mods: SS wheels, 2.5" Cowl Hood... New 100% Black paint job, Clear Side Marker Lights
Stereo: Alpine 855, Infinity Kappas all around, Infinity 150x2 amp (POS), Infinity Perfect 10 in hatch.
Pictures at http://albums.photopoint.com/j/Album...a=13605035&f=0 Here
ICQ: 1437212
AOL: normalmatt9
91 Z28
Best Time Slip:
60' - 2.098
ICQ: 1437212
AOL: normalmatt9
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Lower the engine down to 100 HP and street tires will hook every time.
No suspension product in the world will let you hook up with street tires if the engine simply overpowers them.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
I was afraid of that. Lets not say street tires... just street legal. E.T. Streets. Capable of making those hook?
91 Z28
Best Time Slip:
60' - 2.098
ICQ: 1437212
AOL: normalmatt9
91 Z28
Best Time Slip:
60' - 2.098
ICQ: 1437212
AOL: normalmatt9
Car: 4
Engine: 6
Transmission: 5
LCA lowering brackets, LCAs, better torque arm, SFCs
ICON Motorsports
ICON Motorsports
Car: '89 Firebird
Engine: 7.0L
Why are you so concerned about 100% traction? Fast cars can roast off a set of slicks if desired. The key is self control. You're asking the wrong question. You'd get much better results making a new post asking what suspension mods are worthwhile to help maximize traction on the street... if that's what you're after. That's the exact reason why the driver is important in a race. You could have a 500 Hp car stuck in the 13s if you can't throttle it properly off the line.
[This message has been edited by QwkTrip (edited August 27, 2001).]
Right on QwkTrip.
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Accel Cap and Rotor, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Gutted Air Boxes, 8mm Wires, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"It's not the ricers, it's those damn V8's!"
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro, 2000 3.8 5-speed Camaro.
Car: 87 IROC L98
Also getting traction on the street and traction at the track are 2 different things. Trying to get traction on asphalt is hard. It's not a good smooth surface but has many pebbles and bumps which are slippery. The launch pad at a drag strip is a smooth concrete surface usually with VHT traction compound sprayed on it to make it more sticky. When a launch pad has over 1/2" of rubber built up on it the traction gets worse and the pad needs to be scrapped.
It is possible at 350 hp with an automatic, but will require drag radials/suspension components. Go with a tubular rear suspension, torque arm, correct torque converter, drag springs/shocks, no front sway bar and Nitto or preferably BFG DR's, and you should leave hard. My Formula only 217 has rwhp, but has cut a 1.89 and a bunch of <1.95 60' times. This is with a very mild converter (1800 rpm foot stall). This is in full street trim just like I drive it everyday with stock springs/shocks, and can probably duplicate that from a stoplight. All it has is LCA's, panhard, cheap converter and Nitto's.
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
[This message has been edited by 98_1LE (edited August 28, 2001).]
