Double Diamond strut tower brace in 4130
Old Oct 11, 2010 | 01:04 AM
JERRYWHO's Avatar
It was time for a new strut tower brace so this is it. All 4130 and Tig welded.
Jerry
Attached Thumbnails Double Diamond strut tower brace in 4130-img00039.jpg   Double Diamond strut tower brace in 4130-img00042.jpg   Double Diamond strut tower brace in 4130-img00041.jpg
Old Oct 11, 2010 | 02:30 AM
TwinTurboROC's Avatar
Re: Double Diamond strut tower brace in 4130
is'nt this the same design as before? or is this an updated version?
Old Oct 11, 2010 | 03:17 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Looks great Jerry. I bow to your fab. skills.
He changed the design twin turbo. There is no "plate" in the middle. Looks to me like there is more clearance above the TPI unit.
Old Oct 11, 2010 | 04:42 AM
88gta6spdvert's Avatar
Car: 99 3000gt 88 gta vert 88 gta h/t
Engine: v6 /5.0 /5.7
Transmission: at/5 speed/at
Axle/Gears: ? /3.45/3.23
is that ronals on your ride? if so wanna sell?
Old Oct 11, 2010 | 06:29 AM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
did you build that yourself ? cause that must make for a damn stiff front.
can you make some for your F-body buddy's here
Old Oct 11, 2010 | 08:15 AM
JERRYWHO's Avatar
This one is updated to fit a new hood, mount to the brake master and will locate and tie into some new custom strut mounts for more accurate camber changes at the track.
Jerry
Old Oct 11, 2010 | 08:19 AM
JERRYWHO's Avatar
The wheels are custom made 91-92 Camaro wheels.
https://www.thirdgen.org/forums/whee...-modified.html
Jerry
Old Oct 11, 2010 | 05:58 PM
As always jerry very sick, and its good to see your still around, atleast there still a few old "faces".
Old Oct 11, 2010 | 06:14 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
looking good as usually Jerry, make me one?
strut mounts look similar to the hotpart ones, but seem to be taller? did you make them too, or am I totally wrong?
and couldnt help but notice the overflow and washer fluid canisters. The coolant one looks like a canton, unless you again, made it, but what about the matching washer reservoir? Thats something i've been waiting for somebody to come out with, or is it just painted
Old Oct 11, 2010 | 07:41 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
very nice. How much if you make more? Would love to add that to my vert.
Wonder if the front bar would hit my Novi2000 on the D.side front bar.
Old Oct 12, 2010 | 12:09 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Jerry can you speak to the improvement this has been over no strut bracing at all? I've been going to do something like this but I'm having clearance problems getting a bar to go over my super ram under my stock IROC hood. If this is worth it I'll put the time in to come up with a solution.....
Old Oct 12, 2010 | 12:35 PM
JERRYWHO's Avatar
The strut mounts on the car right now are from Hotpart. The new ones are still on the mill and will interlock with the strut tower brace.
You don't miss a thing. The coolant tank is a copy of the Canton part and when i made the pattern for it I made one for a washer tank. Both are all aluminum and at first I had them polished, but it was to much bling for me so i had them black powder coated.
Jerry
Old Oct 18, 2010 | 01:31 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
very impressive work on the STB, I wish someone out there sold something even remotely similar to this.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
