strange shake on take off, any Ideas?
Old Sep 4, 2001 | 11:30 AM
rollbar's Avatar
A strange thing happens when I stomp the gas. The tires break loose and spin like normal, however, when they catch traction the car shakes violently like something is winding up and letting go until I let off the gas and let the car accelerate more slowly. What remedies if any do you know of?
Old Sep 4, 2001 | 12:51 PM
82camaro's Avatar
Car: 82 camaro SC
Are you talking about wheel hop?
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Sep 5, 2001 | 03:10 PM
rollbar's Avatar
I guess that would describe it.
Old Sep 5, 2001 | 09:20 PM
Tas's Avatar
Tas
bad U joint? loose torque arm? Tranny mount?
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Sep 5, 2001 | 09:38 PM
rollbar's Avatar
I guess I better crawl under there and feel around. Hope its just a loose bolt. Any other diagnoses are welcome.
Old Sep 6, 2001 | 03:44 AM
AntiVTEC's Avatar
You might have worn out rubber bushing out back in the control arms. just by crawling under and tryin to move things around wont show anything is bad. take the control arms out and have a look.
Old Sep 6, 2001 | 12:52 PM
rollbar's Avatar
It seems like I need upgrade the suspension all around the car. If I were to upgrade what suspension packages would anybody recommend. I would appreciate it if you would include price. Any other suggestions on the take off problem are still appreciated
Old Sep 6, 2001 | 01:04 PM
Tas's Avatar
Tas
http://www.ws6.com/f-bodygp.htm
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Amillionoh7
Sep 5, 2015 11:44 PM
SG91camaro
Sep 5, 2015 10:27 PM
IROCtometal
Sep 2, 2015 02:01 PM
