WS6 vs Eibach Sportlines
Old Sep 8, 2001 | 10:51 PM
91Firecrow305TBI's Avatar
Hello, sorry if this question has already been posed, but I have the opportunity to acquire some WS6 springs for around 20 bucks. I had been planning to go with the eibach sportlines. The fact that it will cost me another 200 for the latter does not matter to me, unless they perform similarly.
How do they compare? I want my car to stick to the road, and I am not worried about a bumpy ride.
I have the level 1 suspension with the
following mods;
GM Wonderbar
Homemade subframe connectors
Soon to come;
36mm front, 24mm rear sway bars
Homemade strut tower brace
Thanks,
Clint
Old Sep 8, 2001 | 11:15 PM
nicmike85's Avatar
You must first decide what speed you want your car to stick like glue. Everything is a compromise so you've got to pick. you can set it up for high speed handleing like road racing or flying along at 130 or so through corners. Or you can go towards slow course racing like solo or a tight corner carver. Think about what you will be doing in the car most of the time and be honest with yourself. Another tip is lighter is faster and handles better all the time.
Old Sep 9, 2001 | 03:22 AM
AntiVTEC's Avatar
sportlines will be slightly stiffer, but definatly lower. i've had em on my car for about 5 years and super happy with them.
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Accel Cap and Rotor, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Gutted Air Boxes, 8mm Wires, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"It's not the ricers, it's those damn V8's!"
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro, 2000 3.8 5-speed Camaro, ~68 Chevelle 350, 92 CRX Si.
Old Sep 9, 2001 | 09:12 AM
Well there is one corner I love to carve through everyday, It basically a semi-circle. The governor on my car stops me at 115, and it feels very stable at those speeds, but I really do not need to be going that fast anyhow. I would want max traction in corners, but decent traction in straight line acceleration, too. I plan to switch to 4th gen wheels too(275/...), sometime next year.
They have an event at the local 4/10m circle track for us street drivers, and a good suspension is key.
Hit me back please,
Clint
Flowmaster 80 series muffler
no Air/Cat, straight pipe
no smog pump/pulley
K&N Open Element cleaner
Ultimate TBI Mods
1" TBI Spacer .25" Injector Spacer
Homemade Subframe Connectors
GM Wonderbar
lead pedal foot . See my project rocket turtle @
http://oursportscars.homestead.com/firebird.html
Member of Tidewater Trans Am Club
www.ttac.net
Old Sep 9, 2001 | 01:50 PM
nicmike85's Avatar
What kind of banking does your track have and how often will you run there? Sounds like you need a tight set up with the option to put the circle track alighnment when your playing on the weekend. The problem occurs when you need a diferent set up for left hand turning and the street. What kind of competition will you see at the track? Street cars or local track cars?
Old Sep 9, 2001 | 04:01 PM
Well I know I do not have something to compete with everyone, but this event includes anything from station wagons to C5 Vettes, T/A's, & Supercharged Mustangs. I would say it is a 20- 30 degree banking turning left at all times. More banking on the outside lane. These are all street cars.
Old Sep 9, 2001 | 09:15 PM
nicmike85's Avatar
Just to try and sum up this topic. I think you should invest in a couple of chassis books. You would find them very interesting and they provide lots of entertainment. With the street set up you might want to stay with a factory spring or even a softer one for the bumps on the road. Racing at the track however you would want a stiff spring especially on the right front. If the track was flat you could use softer springs and put in stiffer sway bars (this would be good for the street). The high bank track needs harder springs to keep the car from rolling over. Maybe a good compromise would be drop springs since they are harder. Sway bars help but will over load the left front on high banked tracks. Good luck and have fun.
Old Sep 9, 2001 | 10:02 PM
I appreciate all of the advice, sounds like I really have a lot of learning to do . Just when I thought I knew something about my car...
I'll pick up the WS6 Springs
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
gta_knight
Sep 23, 2015 04:59 PM
jbates346
Sep 22, 2015 05:22 AM
Chiknhawk
Sep 10, 2015 08:55 AM
