help control arm question
Old Sep 29, 2001 | 01:23 AM
Camarokid01's Avatar
if I get the spohn control arm relocation brackets what control arms should I buy with them
Old Sep 29, 2001 | 07:49 AM
ede's Avatar
ede
the stock controls arm will work. the LCA brackets allow you to optomize the pinion angle, in effect you move the rear end and the LCA brackets are adjusted to bolt up the the control arms then welded to the exsisiting factory lca brackets.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Sep 29, 2001 | 04:41 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
<font face="Verdana, Arial" size="2">Originally posted by ede:
the stock controls arm will work. the LCA brackets allow you to optomize the pinion angle, </font>
The torque arm is soley responsible for the pinion angle. Control arm re-locating brackets will not affect the pinion angle.
You can use any stock or stock replacement control arm w/ re-locating brakets.
Old Sep 29, 2001 | 05:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Right... a properly designed LCA bracket (the Spohn for example) puts its mounting holes in the same "arc" of LCA motion that the original one are in; so the wheelbase does not change, pinion angle does not change, or any of that. The LCAs are teh only thing that is moved.
I have the Lakewood ones on my car with a Spohn torque arm and brackets.
ICON Motorsports
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
