whats involved in installing poly. bushings in LCA's
Old Oct 13, 2001 | 07:43 PM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
i was thinking of boxing my stock LCA's and i hear installing the bushings is a pain in the a**. if not where would i get the poly bushings? and do they come with grease fittings?
white/gold GTA ,leather new 5.7TPI ,S/R torker 2.02 1.60heads comp cam 212in 218ex dur. .475in .495ex lift. edelbrock headers ,dyno 2000 says 337 hp 405ft lbs of tork..700r4 3:27posi twin cats,3"catback,aluminum d.shaft ported plennum,afpr,8mmwires,k&Nand all other "free" mods, performance resource chip,SLP cold air intake.
Old Oct 14, 2001 | 08:37 AM
ede's Avatar
ede
call 800-345-4545 and thell them what you have and what you want, ES ploy bushing for the rear LCAs. remove the LCAs and do the welding then press out the old bushings and press in the new. it isn't hard and doesn't take very long. there is no provision for a grease fitting, same as factory.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
TheExaminer
Aug 25, 2015 07:34 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
NBrehm
Aug 5, 2015 07:57 PM
