Torque arms
Old Oct 18, 2001 | 07:38 PM
bidle98's Avatar
Car: 92 RS Camaro
Engine: 406 sbc
Transmission: 700R-4
Torque arms
Who makes the best aftermarket torque arm? I have been looking at the radum tech one, seems really good.
Old Oct 18, 2001 | 09:49 PM
iroc5speed's Avatar
spohn makes one I believe, and so does random tech. Either one will be good.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
Old Oct 19, 2001 | 02:46 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
http://www.bmrfabrication.com/
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Oct 23, 2001 | 02:36 PM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
Spohn's gets my vote all of the way...
very High quality
Old Oct 24, 2001 | 08:41 AM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Anyone using the Chassis Engineering torque arm?....Saw it in Chevy Hi-Performance Mag in an ad, $299, mounts to car instead of trans, adjustable w/ spherical rod end. Just curious, for $55 more I could get the Spohn w/ the Tremec crossmember but want to weigh all my options.
'91 Z28 1LE; 355, Sportsman II heads, Edelbrock TPI w/ 58mm TB, Tremec TKO 5-speed, 3.73's & much, much more
Old Oct 24, 2001 | 11:05 AM
sharon's Avatar
Car: 83 Sport Coupe
Engine: 383ci
Transmission: turbo350
Edelbrock make one also. It's the cheapest I've come across at $146. Anyone know how good that one is?
New and Improved, ie Not so Cheesy
Sharons Virtual Junkyard
Old Oct 24, 2001 | 05:37 PM
cort351w's Avatar
look on ebay. I found two different ones (might have been global west) the other day goind for like $100 dollars. Just not enough people want them for them to auction well.
Old Oct 24, 2001 | 08:03 PM
Ezey Go's Avatar
I know Jegs also makes one.It runs $260.
Old Oct 25, 2001 | 09:24 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Spohn Have the BEST on the market, and I have look at all the ones mentioned. I get his after a lot of research and as far as I’m concerned I would never get one other there Steve’s. IMO….
Now I HAVE_A_Z
89 IROC 350 TPI
Old Oct 25, 2001 | 07:04 PM
The Man's Avatar
I also have to agree. Spohn is the best. I have had one and loved it. I will buy another when the time comes to change trannys.
Old Oct 26, 2001 | 04:00 PM
David Petersen's Avatar
I don't have one now but when I buy ( in a few weeks) it will be Spohn. I have his drive shaft and SFC and both are of the highest quality and a perfect fit. I thought I could save a few bucks and get one through S&W Race cars BIG mistake it ended up costing more and didn't fit and they have a restocking fee on top of that. Rip off artists!!!!!!!!!
Old Oct 29, 2001 | 09:01 AM
Ed1LE's Avatar
Engine: 5.7, 5.0
I did a lot of reading over the weekend & Spohn looks like the best bang for the buck! Unlike the Jeg's, Random Tech, Mac, etc. it doesn't mount to the stock trans location, they give you a choice of poly mount or rod end & depending on your application, many of the Spohn's have driveshaft loops & crossmembers (so I can get rid of those cheesy trans adapters that came w/ my Tremec!)....for $355, vs. BMR's extreme duty for $550. My plans are to order one in the next week or so along w/ the control arm relocation brackets & the LPE 3-3/4" aluminum driveshaft...forget about this months car payment!!!!!!
Old Oct 30, 2001 | 12:46 AM
812MANY's Avatar
The Chassis Engineering TA is a POS!
Its basically a ladderbar with 2 adapters.
It bolts through the floor (gotta pull the interior), and hammer the **** out of the floorboard, It MIGHT work a little better with their SFCs, but it also has the drawback of having a solid front mount (supposedly binds up), and you can NOT run the factory exhaust (it goes right through the TA crossmember.
The only reason I'm running one is because someone gave it to me, and I ripped the tranny crossmember out twice (previous owner rigged the factory TA to it in order to install a TH350). It transfers a little road noise, but it hooks like a *****!
It DOES work, but there are just too many compromises for me to sugguest it to someone when there are better alternatives.
[/rant]
JK
Anyone know who makes a good, inexpensive 4-link kit?
Old Oct 30, 2001 | 07:49 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
The jegs TA does not mount to the original location. It bolts to the bottom of the car using a saddle bracket. Interior removal is required as is drilling a lot of holes for the 3/8 inch bolts. 17 of them i think.
Old Nov 1, 2001 | 08:36 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
My jegster arm lifts the whole front of my car in the air. I was told it was very effective b/c it is so short. I have people asking "how the hell did you get your car to lift like that" Hard install though
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
