Who likes drag launch springs?
Old Nov 1, 2001 | 08:14 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I was wondering how the Eibach springs work and how drivable the car is after installation? I have drag radials, lcs, torque arm, and more than enough power to spin my tires. Are these suggested?
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Old Nov 1, 2001 | 08:23 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I was looking at these in Summit today, too. I'll add a question: What shocks would you guys recommend to use with these springs?
89 IROC-SuperRammed 355 w/ AFR 190's and LPE 219/219 cam-http://www.geocities.com/buckeyeroc
Old Nov 1, 2001 | 09:29 PM
Trent257's Avatar
are these the ones that are supposed to take .2 to .4 off your ¼ time, i too was also looking at them today in summit, they worth it, can you drive with em on the street
Trent
---Car---
89 Firebird/305 L03 TBI A4/t-tops
Open Element Edelbrock Aircleaner w/ K&N air filter/Summit Chrome Valve Covers
Edelbrock TES headers 3" out/flowmaster American thunder 3" exaust/Catco cat
---Stero---
Pioneer DEH-P730 Premium
Infinity 2way 4652 4x6's/Pioneer 4way ts-a6985 6x9's
profile cl640 110x4
Old Nov 1, 2001 | 09:36 PM
Car: 1991 Firebird
Engine: 427 LSX
trent, thank you for reiterating my question.
Old Nov 2, 2001 | 11:03 AM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I have just ordered mine. My suspension currently consists of:
Random Tech Torque Arm (pinion -4 degrees)
Poly trans mount, TA mount
Edelbrock lca
hotchkis panhard rod
STOCK ws6 springs
air bags in springs
lakewood 70/30 drag struts
lakewood 50/50 drag shocks
SFC
removed front sway bar
The car currently has a best 60' time of 1.63 on slicks.
I am switching to the Drag Springs to see if there is a difference. I won't be able to let you know untli next season.
Any thoughts on these springs?
1991 Formula, 406, miniram. Best run to date (9/30/01) 60' 1.63, ET 12.28, MPH 110.48
Old Nov 2, 2001 | 11:04 AM
Car: 1991 Firebird
Engine: 427 LSX
what do you run your air bags at??
1991 Firebird
AFPR,Lakewood lcas
AFR 190s
autopower rollbar
Old Nov 2, 2001 | 05:34 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
13 lbs. each
Old Nov 4, 2001 | 11:30 AM
Car: 1991 Firebird
Engine: 427 LSX
why have airbags and run them at the same pressure?
Old Nov 8, 2001 | 06:48 PM
BuckeyeROC's Avatar
<font face="Verdana, Arial" size="2">Originally posted by GofasterFirebird:
</font>
Anyone else???
Old Nov 8, 2001 | 10:21 PM
iroc5speed's Avatar
I've asked this question several times at several different boards and noone seems to have them. I just want to see if they're good for the street, and if the spring rates are lower than stock. I need stiffer springs because sometimes I hit the wheelwell woth the 4th gen rear.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
sailtexas186548
Aug 26, 2015 03:32 PM
TheExaminer
Aug 25, 2015 07:34 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
