UMI Front A Arms? Issues?
Old Nov 21, 2010 | 09:00 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I bought the whole Spohn setup a few months back and got it all installed and I am disgusted with the fitment of the Spohn A arms and how far back they make the tire sit in the wheel well. Has anybody had issues with the UMI units in having the wheel sit back farther in the wheel well? I'm getting massive tire rubbing on stock tires.
Old Nov 21, 2010 | 09:17 PM
Guest
Guest
Posts: n/a
Re: UMI Front A Arms? Issues?
Do you have pictures? Are the arms adjustable ones or fixed length units? I f they are fixed units then it sounds to me like someone used the wrong jig in fabbing yours.
Old Nov 21, 2010 | 10:10 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
non adjustable. From multiple posts about Spohn Arms it seems common. A ton of complaints about the wheel sitting back farther.
https://www.thirdgen.org/forums/ltx-...-k-member.html
Post 12
Post 52
https://www.thirdgen.org/forums/susp...ims-spohn.html
https://www.thirdgen.org/forums/susp...completed.html
post 32
Old Nov 22, 2010 | 12:25 AM
Guest
Guest
Posts: n/a
I read those post and am mostly shaking my head. There are no factual basis to anyones arguements.
What I se is a few people doing brake assembly changes at the same time they are installing these A-arms...so...the brake packages will offset the track width wider and cause the wheel to hit the rear of the fender wheeel at full lock since it swings in a larger arch.
Then there is talk of how everybody was so careful in marking their alignments prior to disasembling the old a-arms and replacing with the new tubular ones- well surprise people, the old bushings are worn and will set the arms in a different position than the new arms with NEW bushings- OF COURSE THE ALIGNMENT WILL CHANGE AND HAVE TO BE CORRECTED!!!
It is NOT the A-arms being different that stock configuration.
Heck, just unbolting the struts from the spindles and then reataching them later will slightly alter the alignment specs from slop play in the componant marraige.
Old Nov 22, 2010 | 07:40 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
So putting back on stock ones and it going away is not factual?
Old Nov 22, 2010 | 07:42 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
But its the entire tire that sits back farther. Not outwards or alignment off its the whole physical tire. It looks goofy...
I agree the big brake setup will stick the wheel out farther, but not sitting back a ton. I swapped out good A arms with poly bushing and new BJ and I;'m not worried about alignment issues. Its like the balljoint is sticking farther back to the rear of the car almost an inch.
Old Nov 22, 2010 | 09:33 AM
Guest
Guest
Posts: n/a
Originally Posted by Vetruck
Do you have pictures? If they are fixed units then it sounds to me like someone used the wrong jig in fabbing yours.
bump
Old Nov 22, 2010 | 11:09 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I am going to try to get some. Car is in storage but I should be able to run over to the place this week and take a pic. I'm worked on these cars for a long time now and usually know whats good but needs adjustment, but this is way too extreme. I'll keep you updated.
Old Nov 22, 2010 | 11:55 AM
87350IROC's Avatar
Car: 87' IROC
In case you are considering the UMI arms. Please be aware they have several issues.
First they do not have a spring index so no means to locate the end of the spring. They also do not have steering stops.
Both the UMI and Spohn do not have bump stops. So you need to figure something out there too.
Old Nov 22, 2010 | 02:00 PM
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
Spohn sell shock bumpstops and offers steering stops on the A-Arms.
Old Nov 22, 2010 | 02:48 PM
87350IROC's Avatar
Car: 87' IROC
Word is the Spohn stops don't work with spring perch version UMI A-Arms.
And Spohn's bumpstops are way overpriced. I recommend the Ground Control ones.
Old Nov 22, 2010 | 06:21 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
U mean the spohn steering stops? Cuz then you are correct, they do NOT work with UMI perch style a-arms.
Old Nov 24, 2010 | 02:23 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
Big issues right there. I had a thread a while back on umi a arms. Haven't driven my car that much.
Old Nov 24, 2010 | 09:14 AM
What is the link to that thread? I would like to know if I wasted 500$ on these things... Thanks
Old Nov 24, 2010 | 07:56 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
I just purchased the BMR units with the stock spring pockets since they are having a sale for the holiday weekend, great price, looks like a very nice arm with the bump stop. I'm hoping this is not an issue with these. I'll let you know as well as before and after pics when I install them this winter along with the new adjustable struts I bought.
Old Nov 25, 2010 | 10:20 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Sounds great. Seems your not too far away from me either. May have to check out your ride one of these days.
Old Nov 26, 2010 | 06:55 AM
UMI Performance's Avatar
Our A-Arms are designed to keep the tire in the factory location. There will be no issues with the tire moving back or forward.
I hope that helps!
Ryan
Old Nov 26, 2010 | 07:30 AM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Yea, that would be cool, I have it jacked up on stands and have started the tear down for the new stuff. Pretty cold this morning, glad my garage is heated.
Old Nov 26, 2010 | 11:02 AM
Ryan, how come there are no steering stops on the UMI a-arms?
Old Nov 26, 2010 | 02:00 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
second that.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
