a quick ?'s on subframe connectors
Old Nov 23, 2010 | 09:27 AM
mattyc's Avatar
Car: 1998 grand cherokee, 1988 iroc z
Engine: 350 tpi
Axle/Gears: ???
i do know its a pretty good idea to get them in higher horse powered cars.
i looking at an 87 iroc with a 450hp motor in it and 373's in the rear. does not have the connectors now.
the car has T-tops, what would i look for to see if the the car is twisted (if that's an issue)?
and is there a magic hp rating when one should install them?
any info would be great, thanks
Old Nov 23, 2010 | 09:52 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: a quick ?'s on subframe connectors
Look at the C-pillars / rear t-top areas look for signs of cracking, bends or tares in the sheet metal etc. there are other stress areas as well but those are the easiest to find. so this is a car for sale your looking at? ask for the dyno sheet and what it had on it at the time of being dynod, i can almost guarantee if he isn't running sub frames now i doubt theirs 450hp.
There is no magic number these unibodys were lacking in chassis reinforcements as soon as they rolled off the assembly lines.
Old Nov 23, 2010 | 11:52 AM
mattyc's Avatar
Engine: 350 tpi
Axle/Gears: ???
thanks, this is a good to know info. i did plan on asking for paper work to prove all claims. usually their facial expressions tell the story when you ask for this stuff face to face.
gta892000
Aug 11, 2019 11:16 AM
corey8084
Sep 17, 2015 02:56 PM
ccop
Convertibles
Sep 14, 2015 04:13 PM
Nick McCardle
Sep 10, 2015 08:36 PM
