Front suspension parts- good brand names?
Well, along with replacing my front rotors on my '84 T/A, I'm going to go thru and replace all the ball joints, tie rod ends and bushings. Any good manufacturers out there (or at least any bad ones I should stay away from)? I'm looking for a stock rebuild, btw if that makes a difference.
Thanks!
Original owner - '84 T/A w/stock 305HO 5-speed
Thanks!
Car: 91 camaro
Engine: 383
Moog is good stuff. Stay away from the cheap chinesium, basically what you pay for is what you get.
91 Z28
Come see The Vicious...
91 Z28
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Yep, Moog is the best stuff.You can mail-order 'em now from Summit,too.
Otherwise, most stores carry TRW,which aren't bad,but definitely stay away from any offshore manufactured stuff( especially Chinese),the metals overseas are pretty soft.
Rich
Rich
Car: 1983 Z28
Transmission: WCT5
Hehe,
I'm designing tooling for Moog products as we speak!
We build good stuff!
A LOT of the chain store brands are made by moog also. Check out your store's house brand and see if it's moog. This is many times the low line stuff, but still good and may be had at good prices!
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
Clem
Yea I'm leaning towards Moog right now over what other brands I've seen out there that's available for Firebird front-end components.
One thing I noticed tho- Moog has 2 different ball joints available for '84 T/A- a standard version and a 'improved design' version. Does anyone have any idea as to what that 'improvement' is?
Car: 1983 Z28
Transmission: WCT5
If you can email me the part numbers, I'll look up the part prints and can tell you what exactly is different about them. It is probably a difference in the internal components (spring types, material ect.) but not sure unless I look.
thanks
Clem
thanks
Clem
Car: 1986 Firebird
Engine: 2.8 V6
Well, they're a Federal Mogul company, so hop to http://www.federalmogul.com. On the left, click on "US & Canada", then click on "Chassis (or Moog)". Then, if you want to go into their electronic catalog, hunt down "Chassis & Steering".
The normal lower balljoint is K6145, the "enhanced design" one is part # K6145T. Summit actually wants $2 more for the normal balljoint... go figure. (For SummitRacing.com, put "MOG-" in front to search for part #'s.) And wow, we've got a common balljoint, eh?
-Tom P (Hot rodded 1986 Firebird 2.8l)
<font face="Verdana, Arial" size="2">Originally posted by clemsparks:
thanks
Clem</font>
thanks
Clem</font>
I think the "enhanced version" is actually a slightly heavier-duty application for light-trucks, but work on F-Bodies as well. That's what the guy at the store told me when I bought my Moog balljoints.
"You want the standard, or the good stuff?"
"The good stuff, why what's the difference?"
Car: 1983 Z28
Transmission: WCT5
Hey,
Sorry, turns out those parts are built at another plant and I don't have access to the prints on them
. Usually it seams that the heavy duty or enhanced versions do indeed have a design improvement incorporated in them.
Clem
. Usually it seams that the heavy duty or enhanced versions do indeed have a design improvement incorporated in them.Clem
Hey,
Clem</font>
Hey,
. Usually it seams that the heavy duty or enhanced versions do indeed have a design improvement incorporated in them.Clem</font>
