alternate way of lowering guys i need your opinion
Car: Chrysler 300c
Engine: 5.7L Hemi
Transmission: 5spd auto
Axle/Gears: 2.89
i was at the parts store tonight and i seen these shackles you connect them to 2 coils and tighten and the pull the coils together lowering the car. they are removable and adjustable you can get a full coil with each shackle and it is $4.00 a shackle. what do you guys think
thank you
Paul
Moderator of the Ontario board
1987 Trans AM
IN PROGRESS
t5 swap
status:
swap complete
MAIL ME
paulhughes@home.com
KILLS:
87 IROC-Z, 79 Corvette, 93 Honda civic si , 88 MUSTANG H.O, 98 Mustang , 99? Dodge Ram 2500, 95 Acura Integra, 00 Cavalier z24, many many ricers
Favorite losses
87 Grand National, 99 Viper Rt/10, 69 Firebird
my ride
thank you
Paul
1987 Trans AM
- 305 LG4 5.0L
- WS6
- T5 (former 700R4)
- 3.23 posi
- 152,000km
- Black on gold trim
- t- tops
- K&N
- Flowmaster 80 series
- Gutted Cat
- P225 on the front P255 on the back
- Sony X-plod deck
- Kenwood 4 X 6s
- Prestige 6 x 9s
- 2 crunch 10" bandpass
- Boss 500w X 2 amp
IN PROGRESS
t5 swap
status:
swap complete
MAIL ME
paulhughes@home.com
KILLS:
Favorite losses
my ride
sounds kinda like a spring compressor, but regardless, i would reccommend against it as it changes spring travel, shortens it, but does not increase spring rate. let me just say also that there is no tolerance for the installation, you might end up with different ride hheights on all four corners. my suggestion? dont cut corners, buy a set of eibachs, trw's, or hotchkis.
Car: 91 Firebird Vert
Engine: LO3
Don't get them. Like mentioned above thae rate stays the same and there would be no way to insure getting them all even. I know most lower there cars for the lower CG and most springs are stiffer in rate, the result, a tighter handling car. That is why I lovered mine and used stiffer springs. I got my INTRAX sport springs for under $200.00, and they are not that hard to install.
Car: 1988 Camaro SC
Engine: 355 Chevy
Transmission: 700
The advice I am about to give is highly not recommended. If you want to lower the rear end you can take a torch to the coil springs. You can heat up a spot on the coil when it's in the car the weight of the car will bend the spring.
Like I said, highly not recommended. But if one side of the rear is a half inch taller than the other you can heat the coil and let the car lower until it is even.
By the way, I would never do this.
1988 Camaro Sport Coupe: Orignally: 305 TBI 700r4
Now: 1974 355CI, 2bolt, Badger Flat Head Pistons w/ valve relief, Melling high performance street cam, GM Cast Vortec Heads, Edelbrock RPM Air Gap Intake, Edelbrock 600cfm w/ electric choke, GM HEI w/ vacuum advance, Weiand Low Profile Air Cleaner, Mallory 5 port Fuel Pressure Regulator, 3.73 Posi, Mr. Gasket Throttle Cable Bracket, Corvette Shift Servo, 16" IROC Wheels Best Times:60ft 2.26 1/8th 9.68 @ 73.63
https://www.thirdgen.org/rides/index.tgo?action=view&rideid=7480
the thing is, you can save your stock springs and just swap em out if you want it back to stock height. if you think you can just pull them off in the parking lot at work cuz you feel likee it, like ttops, i got news for ya. youre gonna need tools and to take off the tires anyway, and it wont look right, and youll have all sorts of handling gremlinswith them all. its not difficult to swap springs, ive done it in a few hours. but if you can convince yourself, id say its a hassle and a waste of money, not to mention straight out daangerous i.e. taking a corner at 30 and riding on the bumpstops =O but if you think thaat you can sacrifice handling, time and effort just for an uneven lowering job, even temporary, and pay whhat, 20 bucks for it, ok.
Car: 82 camaro SC
Yes you do get a spring rate increase--it effectively removes one coil. It has the same effect as cutting a remove a coil. If you want to try it, I say go for it. It's not expensive and it's easy to change back.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
82camaro
Car: yep
Engine: uhuh
Transmission: sure does
I would never lower a car buy any means other than springs.
Never use the coil compressers or heat a spring.
Cutting coils even stiffens the ride too much for my likeing.
I have seen the comp. come out after hitting a bump, and the coils actually break from being heated, you take the temper out of the spring by heating.
If you are going to do something, do it right.
Aftermarket springs are designed with the proper spring rate and retain a decent ride while working correctly.
Just my 2 cents..
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited November 24, 2001).]
Just my 2 cents..
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
<font face="Verdana, Arial" size="2">Originally posted by Engineboy:
</font>
</font>
Car: yep
Engine: uhuh
<font face="Verdana, Arial" size="2">Originally posted by cort351w:
I would much rather use drop spindles so that suspension geometry is changed as little as possible.</font>
Thank you
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
LT1Formula
Nov 16, 2015 01:13 PM
db057
Aug 11, 2015 10:11 PM
