Tranny Mount Rotted
Old Nov 22, 2001 | 05:05 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
Tranny Mount Rotted
The other day I noticed that my tranny mount was bad. I have been experiencing a problem with wandering and the car feels loose but I doubt that the tranny mount is the cause of these problems.
What would be some of the signs of a bad tranny mount? Would they be very noticable or barely?
Mark
Old Nov 22, 2001 | 09:23 PM
coach's Avatar
When my tranny mount went bad, I would hear a loud thud(under the car) when I would accelerate from a dead stop. I went ahead and bought a polyurethane mount.
Old Nov 22, 2001 | 09:52 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The main sign that you have a bad trans mount (especially in a V8 car) is if it's still the stock style. That's very bad: it's just a blob of spooge pretending to hold the car together. They're a joke.
Get an Energy Suspension one. Don't even worry about trying to figure out if yours is any good or not, it's approximately 100% certain it's toast.
ICON Motorsports
Old Nov 23, 2001 | 10:21 AM
Bluebird's Avatar
Car: 1991 Pontiac Firebird
Transmission: 700R
hhahah I like that analogy..
blob of splooge! hahahaha
yah.. it's not that hard to replacec..
it's worth it to upgrade those to the
new polyurethane mounts, there pretty
inexpensive and they can take abuse.
Old Nov 24, 2001 | 03:25 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
would a bad tranny mount cause the car to feel loose because it is not properly secure.
Old Nov 26, 2001 | 09:15 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I suppose it might; the torque arm goes to the rear of the transmission. While you're at it, replace the torque arm bushing with a polyurethane one (visit http://www.energysuspension.com to find out which bushing your car needs, there's two types)- that made a noticable improvement on my car's stability in turns.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 26, 2001 | 09:50 AM
FiReBReTHa's Avatar
here ya go, and when you slam the gas the tranny hits hard?
sux especially with girls in da car... makes ya look bad, heres some pics i took when install, a lift was nice, and stands to hold tranny nice, unbolt crossmember, unbolt two bolts for mount, crossmember, all done....
here ya go, here was my other post
"Feel that?"
"what"
"no viiiiibrations..."
got it swapped out, you have to edit one pic, cause... you can see, he was trying to Lever the crossmember to bolt it in.
anyways, thanx again for the quick info/advice, we ran thru it in like 20 minutes...
heres the pics,"
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
Old Nov 26, 2001 | 06:34 PM
JPrevost's Avatar
Car: 91 Red Sled
lol, I like those pictures.
Did anybody else have to enlarge the crossmember bolt for the poly unit?
I also think I stripped one of my crossmember bolts when reinstalling. It's in there snug but whatever it screws into is semi loose. I'm not worried about it much, I'll just keep an eye on it for now.
Old Nov 27, 2001 | 11:00 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I didn't have to enlarge the center hole; I just shoved the trans over to the side so it'd line up. The torque arm pushes the back of the trans to the side a bit; once you pull the trans mount, the trans/engine is just held to the car with the two engine mounts, so it can twist left/right...
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
