brakes for a Dana 44
Old Nov 24, 2001 | 12:32 AM
valu8or's Avatar
I just bought a Dana 44 rear from SLP and am in need of some disk brakes. I have a few questions. Can I put rear brakes from a 96 Trans Am on this rear? If not, What brakes work? What do I need from the donor car? Please help as the rear will be here in a week. thanks
1986 IROC
New Crate 350 w/Vortec Heads, Edelbrock 2116 Vortec Manifold, Edelbrock Performer 2102 Cam, Edelbrock 1406 carb, Hedman shorty headers, Flowmaster Catback, Rebuilt 700r4 w/vette servo, etc..
Old Nov 24, 2001 | 05:12 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It depends what backing plates are on it, if any.
Old Nov 24, 2001 | 02:00 PM
german-motorsport's Avatar
Off Topic , but what did you pay for the 44?
www.camaro-firebird.de
Old Nov 24, 2001 | 05:18 PM
valu8or's Avatar
Paid $1,770 delivered from SLP
Old Nov 29, 2001 | 07:59 PM
valu8or's Avatar
Has anyone ever done this? I was hoping ot put a 98+ rear disc system on this rear.
Old Nov 30, 2001 | 05:10 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The Dana 44 takes the same backing plates as the 10 bolt, so you should be able to do it with no trouble.
Old Dec 22, 2001 | 02:46 PM
valu8or's Avatar
I got the rear and I have a set of '86 disc and a set of '86 drums and neither one fits. both of the backing plates are different. The holes do not line up for the disc and the drum appears completely different. Anyone have any ideas? The disc appear close, and almost look the same as the axle end, but it just will not work. Thanks for any input before I have to go buy Baer brakes.
Old Dec 22, 2001 | 09:50 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Drill new holes in the backing plate
Old Dec 23, 2001 | 12:48 PM
valu8or's Avatar
If I do drill the new holes will it affect the integrity of the backing plates at all?
Old Dec 23, 2001 | 03:48 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Have you tired asking SLP what they recommend?
I'd think you need to go with a 4th gen. rear brake set up but don't quote me on that.
Old Dec 23, 2001 | 06:05 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You might already have 89+ backing plates? On SLP's website they recommend use Baer brakes.
Old Dec 23, 2001 | 10:02 PM
valu8or's Avatar
Are 12 bolt and 10 bolt axle flanges the same? From Wilwoods site the flange measures exactly like they show a 12 bolt. I have tried for get a hold of SLP but they are closed for the holidays. When I questioned the "sales expert" about the brakes he said I could use my old drums, but I do not see how that would work. He then gave me the number to Baer and told me to call them. I asked about Baer p/n but he said he did not know. I was hoping to put the rear on over the holidays. Anybody know anything different?
Old Dec 23, 2001 | 11:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I'm not sure, but regardless, it IS possible to put your 86 brakes on if you have the right backing plate. The Dana 44 in my car has them.
I've got some 10 bolt backing plates around here somewhere, I'll measure them if I can find them and compare.
<img src="http://www.precisionbrakescompany.com/precisionimages/12bchev.gif">
Old Dec 23, 2001 | 11:29 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The Baer catalog lists the same kits for Saginaw w/OE rear disc (10-bolt diff cover) & GM Performance Parts Dana 44 conversion rear ends. P/N E4GF-10601-5DN for the rear Touring kit w/ 12" rotors for, or P/N E4GF-10661-5KN for the Touring+ kit with 13.25" rotors.
Old Dec 24, 2001 | 01:14 AM
valu8or's Avatar
That is exactly what the axle flange is like. Thanks apeiron for posting the drawing. Is this a stock axle flange, maybe from a 90 and up Camaro? Does anyone know if the 98 and up Camaro's have the same axle flange? I was thinking of putting some newer LS1 brakes on the car.
I am really trying not to have to get the Baer brakes. I would rather try to get some GM parts as I undersatnd most of the Baer equipment is GM anyway.
I am not sure the axle end that SLP puts on the rears is stock 10 bolt GM. I am getting cash poor buying parts two and three times for the "money pit" I like to call my hobby. Thanks for all of the reply's.
Old Dec 24, 2001 | 02:42 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's a 12 bolt flange in the drawing, I just stuck it up there so I don't have to go looking for it again when I find my backing plates to measure.
Old Dec 24, 2001 | 03:07 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Ok... I found my plates... The 10 bolt disc flange does have the same bolt pattern as the 12 bolt flange shown in the picture, with about a 2 7/8" center hole.
I thought I had pictures showing the differences between the backing plates for the PBR and the Moraine calipers, but it turns out I don't. The plate I'm holding in my hand right now is for the PBR calipers, and the mounting hole centers for the caliper bracket are about 3 13/16" apart, and are about 4 1/8" from the axle center.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
