Q about Spohn D/S loop
Car: 2004 GTO
Will it work fine if I lower my car 1.5"? Will the D/S scrape or rub the loop at all? Also, how far down does it stick out?
Thanks!
Thanks!
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It shouldn't. The loop is at the front of the driveshaft. His loop is attached to the torque arm. To be NHRA legal it must be within 6" of the u-joint. Lowering the rear of the car will have little to no effect on the position of the loop in relation to the driveshaft.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.586
The bolt on loop is about 1.5" below the stock transmission crossmember. You should have ample ground clearance unless you have your car really slammed down low.
Steve
Spohn Performance: F-Body Chassis/Suspension Specialists
Steve
Car: 1992 Z28
Engine: Stock L98 with bolt ons.
Transmission: Stock rebuilt tranny with 2k stall and cooler.
Does your DS loops fit or do you have one that can accomodate a larger diameter aftermarket alum DS (mines a TPIS) to fit my 92 Z28. Id like to invest in one but dont know of one that fits, any info you or anyone else may have would be appreciated...
All of our loops have a 5" i.d. That's the biggest loop you can fit in the tunnel.
Steve
Steve
Car: 1992 Z28
Well in that case you'll be getting my order for that and LCA relocate brackets in the coming months, thanks!!!
darwinprice
17
Oct 11, 2015 11:51 PM
luvofjah
Sep 26, 2015 08:28 PM
