4th gen rear sway bar swap Q
Old Jan 16, 2011 | 02:50 PM
FlippindaBird's Avatar
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
i have a 87 firebird the build sheet designates F41 suspension... i just got a '02 SS rear complete, with sway bar, adj LCAs and a stud girdle for a real good price, the question is; what size is the '02 SS rear swaybar?? just wondering if this is an upgrade or not and if so, how will it work with the stock front swaybar? if this question has been repeated or answered somewhere please point me in the right direction and delete this thread... also what would be the next logical step in upgrading my rear suspension now that i have the adj LCAs... panhard rod or torque arm? im building piece by piece eventually i will have a full aftermarket suspension, but i cant buy everything all at once so i want whats gonna make the best improvement in order, thanks for the help
Old Jan 16, 2011 | 07:47 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 4th gen rear sway bar swap Q
You'll just have to measure to see which one (your stock or the 4th gen) is bigger - there wasn't any 'improvements' in the rear ends from 3rd gen to 4th as far as suspension goes it's all the same.
Old Jan 16, 2011 | 08:09 PM
ok i didnt know if they put bigger bars in the newer ones or not... at the very least ill be able to sell one of them for 20$... on to the second part of the question?
Old Jan 18, 2011 | 03:37 PM
nothingssafe's Avatar
Car: 86 TA
Rear bars on an 02 SS are 19mm.
Old Jan 18, 2011 | 04:07 PM
Car: 1992 RS
Engine: Carbed 350
19mm seems awefully small. I currently have 24mm rear and 34mm front, but I did swap them both in from another vehicle.
Panhard would only be necessary if lowering the rear, as it centers the rear, and if lowering the car the rear will become non-centered (I think the lower you go, the farther towards the pass side the rear axle shifts).
Kind of the same with the torque arm I think - lowering changes the pinion angle of the rear end to the driveshaft, and adjustable torque arms are used to correct that angle by lengthening or shortening the distance of the differential to the tranny (the diff rotates one direction or the other as the torque arm gets longer/shorter).
As I understand it - adj torque arm not really needed for a simple 1in lowering - it's the guys with the hp monster motors that install to get a better hook-up at the track, and where pinion angle tolerances are lower due to the sheer power being applied to rear wheels on take-off.
I think that's right anyway - maybe wait and get a more suspension-savy member to chime in.
So anyway, unless you have a hp monster, or are lowering the car, either could be considered a 'next step'. In my simple mind, I'd think panhard bar before torque arm.
Old Jan 18, 2011 | 04:55 PM
thanks for your input, sounds logical to me newb... im not lowering it and im hoping to get about 320hp or so to the rear wheels, so def not a HP monster lol maybe ill just leave that stuff stock for a while and get some SFCs then... then ill replace the panhard rod, then the torque arm, sound good?
Old Jan 18, 2011 | 06:05 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
bigger does not always mean better.
Old Jan 18, 2011 | 06:43 PM
Car: 1992 RS
Engine: Carbed 350
That's true.
If it were me, I'd worry more about SFC's - and definitely the wonderbar if you don't have that.
Old Jan 19, 2011 | 07:46 AM
yeah no wonderbar its a base bird, i was originally worried that the sfcs and wonderbar would add a bunch of weight, and hence slow the car down, i should be in the 31-3200 range right now...
i think in terms of swaybars, bigger usually means stiffer, and as long as it works with the front bar, id say stiffer is better... its gonna see alot of straight line acceleration, but i do wanna drive it hard on the street and some occasional autocross when i find an event thats a reasonable distance from me
Old Jan 19, 2011 | 10:52 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Mine is lowered 1 inch and I have no torque arm problems. A smaller solid sway bar is better than a bigger hollow sway bay IMO.
Old Jan 20, 2011 | 08:27 AM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Careful putting on a larger rear bar it could induce more oversteer if the rest of the suspension isn't addressed. Now a larger front bar does wonders.....
Old May 22, 2012 | 09:26 AM
91camarosRS's Avatar
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
Found this while doing a search...... X2 in bigger isnot always better. Check out frrax.com
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
z28addict8490
Aug 7, 2015 08:48 PM
