Anyone build a street/strip car with Koni Sports?
Car: 1989 GTA, 1985 T/A
Engine: L98, LG4
Transmission: Slush-o-matic 700R
Axle/Gears: stock and stock
Putting together a street/strip car, 70% street, 30% strip. I have been looking on the boards and talking to various experts (UMI, Strano, local shops, etc.). No one says anything bad about them, but I have heard a few say for a street/strip car, I am spending too much money. Every time I get ready to spend the cash, someone says don't bother. The money can always go other places, so here the question.
Any one have a street/strip car with Koni yellows? For now, lets disregard the rest of the suspension, I know it all needs to work together. Just for this question, do they work on a mild (say 400-500hp MAX) car to get decent strip performance, assuming the rest of the suspension is working as it should? Thanks for all replies.
Car: 89 Iroc
Engine: 305TPI
Re: Anyone build a street/strip car with Koni Sports?
Buy them and don't look back. I could get into a bunch of reasons, but the general consensus is these are the best you can buy. They are rebuildable and adjustable. Perfect for the all around driver.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I highly recommend any decent adjustable shock for street/strip duty. They do work at the strip when set right and when set back into street mode, you can handle with the best of them. Or set them light and go cruise...much softer ride.
I have adjustable tokico illuminas on my car that sees mostly strip now but can handle with its stiff eibach springs and wide tires. It has been 1.4's 60 foots so the suspension works.
Car: 1986 Z28 Camaro
Engine: 350 with .440" lopey cam
Transmission: 6spd T56
Axle/Gears: Detroit Truetrac with 3.73 gears
If you have the cash for them, and they are what you planned to get then just go for it. As the above poster said they are generally viewed as the best you can get without getting into buying a set of racing shocks / struts. Even then you can get Koni Yellows revalved since they can be rebuilt if needed in the future.
If you want to spend less money I'm not going to be one of the people that harp on saying konis is the only choice. You can get by on something a bit cheaper if you are mostly doing street (like you said you were). Only reason I bought Koni Yellows for mine instead of Tokico Whites is because the Koni Yellows went on sale and were only ~100 dollars more than the Tokico's instead of their normal ~280 dollars more. (They are still on sale as far as I know, 20% off at some places. Got mine from tirerack.com)
I finally found someone with a set of Tokico whites a couple weeks ago and he was running a set of springs with a similar spring rate to mine, at an autocross event. I can't really tell a difference in the ride on the street. My konis do feel a little stiffer on the track than the tokico's though. I imagine however if by strip you mean drag strip where you aren't turning, the difference is going to be negligible.
Engine: L98, LG4
Thanks for the replies. Yes, the Tokico's would be the other choice for this application. And yes, Koni's are on sale...I think until May? I will check Tirerack. My issue is shipping across the border. Talked to Sam at Strano and he said he won't ship it to Canada...too many issues in the past. I don't mind spending the cash to do this right. It IS a lot of money, but, I think in this instance, you get what you pay for. Only reason I am reconsidering is I have had 2 performance shops steer me away from the Koni's when I said the application was street/strip. They equate Koni to autocross-only applications. I wouldn't be against autocrossing the car once or twice, but I don't have the wallet to make it hang with a new Z06 'vette, and I think I would get very frustrated trying to do that as well. I can probably be done, but that's not a realistic goal for this car, and that's fine.
By strip do you mean Drag Strip? Because if you do, there is no sense in spending money on konis at all.
If you aren't serious about handling, you don't need konis.
Engine: L98, LG4
Thanks for responding Pablo. Was reading your post on springs the other day, nice stuff.
I am serious about having a car that is fun to drive on the street, take hard around the on/off ramps, and can hook at the track once I put a decent motor in it.
What would you suggest for that application? It will see lots of street miles. Also, I have two drag strips within an hour of me.
I do not have experience with those but I do have koni yellows on my handling car and lakewood 90/10s on my drag car. I would only suggest either of those if handling on the autox course/track (konis) or launch (lakewoods) were a top priority. If you are just out having some fun without any sort of lap times to aim for, I think you'd be wasting money on the koni yellows. You could stretch that cash a lot farther with cheaper shocks and maybe some other mods that would increase your fun factor.
I agree with Pablo. If you were building a car for either end of the extremes the decision would be a little easier. I'm not sure how soon you are looking to pull the trigger on a set of struts/shocks but if you can wait a week or two, I can take you for a ride in my car so you can at least get a sense of how the konis work.
Also, have a look at getting stuff shipped to Port Huron, across the river from Sarnia. either SCC Parcel Pickup or the UPS store there. Any bigger items I have sent there and go and pick them up. Usually saves a fair bit on shipping/duty this way than sent direct to Canada.
Engine: L98, LG4
Pablo, Kevin, thanks for the input. I don't need to pull the trigger soon, just like to make a decision so if I do decide to spring for the Koni's, I don't miss the current sale. Otherwise, no hurry. I do have a place in Buffalo I can ship to, but its just the PITA factor I am trying to avoid. I guess I will take Kevin up on his offer and take the Koni's for a spin. Thanks for the offer Kevin. I actually have a junker 89 GTA with KYB GR2/AGX front/rear on it. Drove it for a few years. It rides pretty firm, but I only have my old pickup to compare to, so anything rides firm comparatively. Really hard to compare handling and ride quality when you don't know what "good" feels like, though I definitely know what "bad" feels like.
Keep in mind that dampers are only part of the equation. If the rest of your car is correct, dampers are a fine tuning tool at the strip (i.e. a few hundredths, maybe a tenth on 60ft times). Great shocks can sometimes crutch a bad suspension, bad shocks can ruin a great suspension. If I had a Koni equipped street car I'd leave the settings as-is and try it. If the front didn't come up to my liking, I'd go full soft on the rebound on the fronts and try it again.
Engine: L98, LG4
That is essentially what I had in mind, using the shocks to tune the suspension.
go with the koni's. Run a regular sport up front. You can run this on the min setting at the track. with the correct spring rates, the front end will settle much faster after launch. On the rear, i would go with a 4th gen rear sport. If you can afford to buy them, get the double adjustables(compression adjustment will be for street use). Crank the rebound to full max at the strip and you will be very happy!
Car: 91 Firebird
Engine: 305 TBI
If your going to buy the Koni's call Autoanything and tell them that tirerack has a lower price then them. The will not only match tireracks price but beat it. Thats where i got mine from.
Engine: L98, LG4
For the time being I'll be running the factory installed WS4 springs. Those should allow the front to lift. Now I thought about the rear double adjustables but Sam Strano said not to bother unless I was running a significantly heavier rear axle. That might happen eventually, but its not in the current plans unless I smoke the 9 bolt. accordlxrj, can you give me some more info as to why you'd run those vs the 4th single adjustables? Thanks.
Thanks for the info murphbird, I'll look into that. Anything has got to be better than Canadian prices, which sucks because I would like to buy from my local shops...we are talking hundreds of dollars difference.
The 4th gen uses a 82 series twin tube and external adjustable. It has a wide range of adjustment. The 3rd gen is a 30 series monotube and not external adjustable.
Engine: L98, LG4
Right, those are the regular 4th gen, and yes, the 3rd gens are only adjustable off the car. What I meant was is there a measurable benefit of the normal 4th gens over the double adjustable 4th gens for a stock axle application?
I would be interesting in the fronts if you are thinking of selling.
Car: 89 Iroc-z
Transmission: TH400
For your power levels, and standard thirdgen suspension, I doubt you will need to go with double adjustables.
If it was a high power radial tire car that needed alot of adjustment, then yes they'd be worth it. But with basic shocks, good supporting suspension pieces and a sticky tire, you can 60 foot very very quickly if you have the power. Suspension as is with regular shocks/springs can take a good launch. I've been 1.41 60 foot with adjustable tokico's, just single adjustable and with the rest of the supporting bolt on parts like LCA's, torque arm, sfc's, etc. Thats on eibach pro kit springs which are stiffer than most drag setups.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Engine: L98, LG4
accordlxrj - sent you a PM
Orr89 - Thanks for your comments. That's sort of why I was questioning the need for the double adjustables. Any reason you went with the Tokico's rather than other brands?
Engine: L98, LG4
I'm not up on my shock technology. Why is the monotube better? I don't relish the thought of having to unbolt the shocks every time I track the car, but if its better, then its better.
Car: 1992 Camaro RS
From frrax's suspension and chassis info sticky thread:
From KYB America's website http://www.kyb.com/service/monotube.php
A thread here on TGO:
https://www.thirdgen.org/forums/susp...ni-yellow.html
And a thread on FRRAX if you're registered there http://www.frrax.com/rrforum/index.php?showtopic=11681
It may not be that big of a deal, and I woudlnt be surprised if the differences in performance are completely unnoticable between the Koni 4th gen twin tube rear shocks and the Koni 3rd gen monotube rear shocks, but on paper the monotube design is superior for all out performance. Whether that translates into the real world, I dont know. I suppose accordlxrj doesn't think it does. But I did want to reiterate that if you're switching from a 3rd gen Koni to a 4th gen Koni to get a better adjustment procedure, you're not really getting the same shock. There are very fundamental differences between the two.
Shocks
Many people use Koni shocks because they are a quality adjustable shock that doesn’t break the bank. The front 4th gen Koni’s are twin tube as are the rears. However, 3rd gen Koni rear shocks are monotubes and can be used on 4th gens. The adjustment is different however. Koni shocks are available in single adjustables (SA) that adjust rebound damping and double adjustables (DA) that adjust both rebound and compression or “bump.” The downside, besides being twintube, is that Koni’s are costly to revalve and rebuild. Another option is to adapt Koni 30 series circle track shocks to the rear suspension-the same holds true for many universal shocks. Koni offers two models of single adjustable struts for the front on 3rd gens, the Specials (red) and Sports (yellow). The Sports have a heavier valving and are preferred for most racing purposes.
The twin tube design is the most common one in use on cars, light trucks, SUV’s and vans. It’s a cost effective unit that provides excellent handling & control characteristics for most driving conditions. The monotube design offers additional performance and can have a more aggressive ride.
The monotube design has a single cylinder:
The cylinder is divided into sections: A fluid area and a gas chamber. The piston and shaft move in the fluid portion. It uses a single fluid valve assembly in the piston. The diameter of the single working cylinder and piston valve is larger than in a twin tube even though the outside dimensions of each may the same. There is no need for an air or gas in the fluid area so the valve can operate more responsively and without any aeration or performance fade. The high pressure gas chamber is separated from the fluid area by a floating piston & seal. That provides an expansion area for the excess fluid movement during the compression stroke. On more aggressive movement the floating piston is pushed further into the gas chamber which increases gas pressure quickly and provides additional damping force. Because of its higher performance capabilities, the monotube design is used as original equipment on some vehicles and offered as an upgrade on vehicles that came equipped with the twin tube design.
The fourth gen shocks are a twin tube compared to the third gen monotube. There's a lot of marketing hype between the two, but it comes down to a monotube has a larger area for displacement and that tends to make it a better performing shock. (I'm glossing over a LOT of reading here)
In terms of fitment you'll be fine. If your road racing or autocrossing it, I'd stick with what you've got. If its just a street car, I'd go for the easier adjustment of the fourth gen shocks.
Originally Posted by trackbird
The third gen is a monotube design. That allows for a larger piston. All things being equal, a larger piston will displace more fluid per inch (mm?) of stroke. This can allow the shock to be more sensitive to low piston speed events (that other shocks might not "notice"). This is all a very general and vague description of the differences, but it can be important.
I've run 4th gen rear DA's on my 4th gen and I tried the 3rd gen rear shocks on my 3rd gen (as an experiment). Honestly, I am very happy with the 3rd gen rears on my car. I've not run them back to back with the 4th gens on the same car, but I like the way they respond.
Yea, that's great, but then you give relatively worthless answers like:
They're better because they are... or because everyone is switching to them... Um sure. WHY?
Some people may be happy with "do this and you'll be happy," but a lot of us want to make our cars do specific things and might have a different approach to what they're doing, so some actual information would be helpful.
Car: 89 Iroc-z
Transmission: TH400
Still have the tokicos on it and they still seem to be working well. Although I think I broke the adjuster on the front struts.... it just spins around and doesnt stop at the highest setting. May need to replace them.Now my auto car launches well. My friends 6 spd car runs mid 10's all motor and low 9's on spray. Its been 1.3's 60 foot now that he has a double adjustable shock on the rear and front I believe. Car with its short torque arm and aggressive clutch just hits the tires super hard and wears out sidewalls. Car in slow motion vid looked like the rear was unloading so he went double adjustable to tune that rear suspension. It worked. Car immediately started hooking better and staying planted. Went from low 1.5's to back into the 1.4's like it should be. Then down to high 1.3's on spray with some adjustments to the spray timing. Certain applications need it but some dont. I've been 1.41 60ft on a mid 10 second pass on spray while he's done the same 60 fts but with 6 spd on mid 9 second passes
Just different requirements for both setups. Last edited by Orr89RocZ; Apr 22, 2012 at 06:59 PM.
wow, technical person working for a company that makes shocks, posting to a technical forum about suspensions to a question about shocks and refusing to explain what we're asking about.
Good job buddy. I'm betting that you've already done enough damage to your company's reputation that some people won't want to deal with you. Of course, I guess you guys are lucky that you're the only real game in town that have a product that really fits that spot in the market...
Car: 1992 Camaro RS
Do you really expect these kinds of poor posts to carry any weight? Even if you're correct, which you very well could be, but no one has any idea one way or another to make up their own minds. Even if you are right, people who are reading through and trying to make up their own minds for their own rides have learned absolutely nothing from your post. If you're not going to contribute anything of value, why bother at all? All it does is make you and your company look arrogant and unhelpful.
Engine: L98, LG4
First, thanks Orr89 and InfernalVortex for your responses. I appreciate it takes time to respond in detail. Second, I agree that accord's response was short, but he did address the question. On one hand, I agree that more information as to the reasoning behind the advice is useful, however, on the other hand, sometimes you don't feel like getting into a huge detailed description on the boards. I know sometimes I don't. I figure at that point, its up to the poster (me) to ask for some clarification, either on the thread or in a PM, rather than get all bent out of shape. Essentially, we are all passionate about the same cars and trying to learn from each other, I just wish sometimes we could critique each other with a little more tact. I'm going for a spin in Kevin's car when he gets his little brake issue fixed, and then I can make a more intelligent decision, which I will post on here. Thanks all.
http://www.ajusa.com/KONI-Sport-Shoc...v6f6q8214.html
AJUSA will also knock another $10 off of $596.92 if you tell them
that AutoAnything will only beat the price by $10
and tell them you found out thru 3rdgen that always helps too
