Need Rear Spring. What/Where to get.
Old Jan 17, 2011 | 11:15 AM
Grifter757's Avatar
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
Trading my ground control setup for a Spohn coilover setup. What should i do for rear springs? Where can i just get rear ones and what size or what not to have the car 1.5" or maybe a little more. Thanks
Old Jan 17, 2011 | 12:54 PM
87350IROC's Avatar
Car: 87' IROC
Re: Need Rear Spring. What/Where to get.
Why the switch? I can think of a few reasons why I like the ground control setup better.
IIRC, people were having problems with the shock bottoming out on the spohn setup on cars that weren't even that low.
Old Jan 17, 2011 | 04:29 PM
Grifter757's Avatar
Car: 87 IROC,
Transmission: 4L80E
Well the Spohn K member and A-Arms make it a PITA to make it go in. Plus a guy wanted to swap so... if i dont like it I'll just put normal springs back on it and call it a day. Wonder why the shock would bottom out...
Old Jan 17, 2011 | 04:57 PM
87350IROC's Avatar
Car: 87' IROC
Oh I see. I thought you were trading your rear weigh jacks for rear coilovers. Now I see you are only trading the front ones. The rear coilovers seem to have more issues that the front. Nevermind.
With that said I did not have any trouble installing GC weight jacks on my Spohn k-member and a-arms.
As for your original questions. SSS makes the pigtail rear springs in a variety of sizes and spring rates. I use a 10" spring along with the stock isolators and GC weight jacks. If you are not using the rear adjusters and want a 1.5" drop, I would try the 11" springs with the isolators.
http://www.pagedezigner.com/bluecoil/2009/pig-tail.htm
Old Jan 17, 2011 | 05:08 PM
Grifter757's Avatar
Car: 87 IROC,
Transmission: 4L80E
Thanks exactly what i was looking for. What weight?
Old Jan 17, 2011 | 05:29 PM
87350IROC's Avatar
Car: 87' IROC
What are you running in the front? What are your goals for the car?
I run 850lb front 175lb rear. It works well and is livable on the street.
Old Jan 17, 2011 | 05:37 PM
Grifter757's Avatar
Car: 87 IROC,
Transmission: 4L80E
98% Stupidly overpowered street car 2% drag strip.
Old Jan 20, 2011 | 11:44 AM
87350IROC's Avatar
Car: 87' IROC
What rate will you be running in the front?
Old Jan 20, 2011 | 07:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
nevermind, wrong end
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Drone358
Aug 27, 2015 11:15 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
