HELP-installing pa racing k member
Old Mar 28, 2011 | 09:57 PM
mongo136's Avatar
Car: 89 camaro rs
Engine: 468 bbc
Transmission: powerglide
Axle/Gears: 373 S-60
I installed a brand new PA Racing k member, it went in perfect, nice fit everything went smooth. Now time to set in my BBC. I got the k member with the provivions for moroso solid mounts, when i went to bolt in the motor the standouts for the mounts the pass side is 1 inch shorter than the driver side, am i missing something or did their fabricator screw up? Motor up/down makes no difference still an inch away!!!!!!
Old Mar 29, 2011 | 06:35 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: HELP-installing pa racing k member
what engine side mounts are you using? the factory ones are different left to right and can cause this issue IIRC
Old Mar 30, 2011 | 07:12 AM
mongo136's Avatar
Car: 89 camaro rs
Engine: 468 bbc
Here's what I found out, one side is supposed to be longer, it is like that to center the motor. The moroso mounts I have are short style, (older). Pa Racing gave me a part number and said there are two different solid mounts, one is a bit longer than the other, thats what I need. When they get here I will give it another try. Pictures will follow.
Rousseau92maro
Feb 1, 2016 05:12 PM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
Linson
Sep 21, 2015 01:08 PM
Mdenz3
Sep 17, 2015 08:36 AM
abray1
Sep 14, 2015 08:18 AM
