AJE Racing K-Member/A-Arms/Coil-over
Car: 1984 Trans Am
Axle/Gears: Stock
I noticed there are not many pics of the AJE Racing K-member, A-arms, and Coil over kit. I just received mine in the mail and thought I would submit it to the greater TGO community.
Here is some info that may also be of use:
Mild Steel construction
0.120 wall tube
0.120 plate
Weight of K-Member 29 lbs
Weight of A-arms (both) 15.5 lbs
Grade 5 A-arm to K-member bolts with nylon self locking nuts
Metric grade 8.8 k-member to frame rail bolts
Road Racing Option:
Support mount for triangle frame rail braces
AJE in-house motor mounting system accepts SBC and LSX motors (Delrin bushings) (will not accept knock sensor)
Reenforced sway bar cross brace
0.120 wall tube
0.120 plate
Road Racing Option:
Last edited by Spin_Phoenix; Jun 6, 2011 at 04:44 PM. Reason: update actual motor mounting method, no knock sensor
Car: 1984 Trans Am
Axle/Gears: Stock
Re: AJE Racing K-Member/A-Arms/Coil-over
Coil over Kit and A-arms
I have a few more pics if anyone is interested, but I think this is sufficient.
I may make a solid model of this k-member for the purpose of performing an engineering FEA test on it.
If there are any design/drafting savvy members out there, you can send me sketches (with dimensions) and I will try to make a solid model of other k-members (with A-arms) out there. Who knows, we may actually be able to find weak and strong points on these products.
Car: 88 Trans am GTA
Engine: 2002 Ls1
Transmission: t-56
Axle/Gears: Ford 9" 4.11 gears w/ locker
how much was your set up all together? does it save alot of weight on the front?
Car: 1984 Trans Am
Axle/Gears: Stock
The cost (to front door) was $999. Hopefully I will be able to get the factory components off this weekend. Once that is done, I will post the weight differences. Jim (shop manager) was very helpfull in plannig my order and answering my questions.
Car: 1984 Trans Am
Axle/Gears: Stock
Results of the weekend install:
The k-member went in without any problems. The A-arms needed to be "persuaded" into fitting.
Sorry these pics are mildly distorted. I cant quite seem to keep the proportion while compressing the pic
Engine: 2002 Ls1
Transmission: t-56
looks good, i bet its much lighter than stock.
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Do the coil overs replace the stock main front springs or just supplement them?
Car: 1984 Trans Am
Axle/Gears: Stock
Car: 1984 Trans Am
Axle/Gears: Stock
I just weighed the stock k-member w/ a-arms. They came in at 82 lbs.
Weight savings table to come soon.
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Could the swap be done with removing the engine etc.? It looks like the engine mounts could be unbolted and the engine supported from above then everything is done from below. ?????
Car: 1984 Trans Am
Axle/Gears: Stock
http://www.streetlegaltv.com/project...is-renovation/
Do u have a part number I went to site and came up with around 12-1300 before shipping unless prices have changed. I need a arms coilovers and BBC mounts (solid if possible)
Car: 1984 Trans Am
Axle/Gears: Stock
CF-30100 (Add RR Brace K-member) $429.00
CF-300 (Add RR Brace bushing style) $320.00
CV-3033 (Add Variable coilover kit) $250.00
Total $999.00
There was a fair amount of phone calls and email correspondence before we arrived at a price. Note: I purchased this set-up while the special was in effect. (That helped quite a bit.)
Call up AJE and ask for James "Jim" Morrow. He was very helpful in helping me design and price my setup.
Car: 1984 Trans Am
Axle/Gears: Stock
I know several folks have been waiting for this post. So without further ado,
Here is the weight savings table!
(summary)
Road Race Option: -39.5 lbs. or 37%
Drag Race Option: -44.5 lbs. or 41%
All weights (with the exception of the stock k-member and a-arms) were taken from the Wii Ballance board. The Drag race weight loss was calculated by removing 24" of 1.5" OD tubing and 18" of 1" OD Tubing.
Also included are pics of the coil over test fit. (driver side)
(summary)
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Does the coil over kit fit a standard (or upgraded) strut or is anything special needed?
Car: 1984 Trans Am
Axle/Gears: Stock
The kit fits the standard strut. The only thing you need to modify on a standard strut (like my Monroe struts) is to knock off the cap on top of the cylinder. See the BMR Coil over kit instructions for a pictorial reference. Basically you take a hammer and chisel and beat the tabs out. Also, the studs on the stock triangle piece are too short to hold all the plates together. I am going to purchase a bunch of new fasteners to hold these plates together.
Car: 1984 Trans Am
Axle/Gears: Stock
I have been very satisfied with the k-member. Installation was a snap. There is a ton of space around the motor to access whatever I need. The header clearance is good (Hooker shorties with associated y pipe.) There are 2 issues the AJE guy and I are working on now. The motor sits a little too high in the engine bay. Nothing a Daytona hood wouldn't fix, however I do not like the look of the Daytona hood on a firebird. (It doesn't follow the lines right.) Secondly the the front end sits a little too high. We are working out exactly which spring will give us the right spring rate, ride height, and suspension travel.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
that is the old design, i had one too. The new design has been flawless for at least 4 years now.
Car: 1984 Trans Am
Axle/Gears: Stock
I got the new engine mount pads that lower the engine about 1" (measured at the mount itself). This places the engine where it should be.
Sorry I had to ressurect this thread, but I figure if anyone is going to order this setup in the near future, they might want this piece of information.
Car: 1991 Trans Am
What are they doing to combat the supposed problem with coilovers causing damage to the shock towers and fenders? I saw a post a couple years ago on here of a GTA that had the Spohn coilovers and it rippled the fenders and I think damaged the shock towers because of the new stresses that were put on them.
Car: 1984 Trans Am
Axle/Gears: Stock
Car: 1984 Trans Am
Axle/Gears: Stock
With the way I requested the k-member, it does not have solid mounts. HOWEVER: The mounts are hard plastic with a steel sleeve (similar to a LCA or A-arm mount/bushing). One could easily machine an aluminum bushing (or request it form AJE) that fits where the hard plastic is.
Look at the far right pic in post #2 for a pictoral reference. Just replace the black plastic (temporary held in by the white tie-wrap) with an aluminum bushing. Then off you go.
Car: 1984 Trans Am
Axle/Gears: Stock
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
I just got my K-meber from AJE, where did you find the lowering Pads, that would help since I am running the HSR
Car: 1984 Trans Am
Axle/Gears: Stock
Your K-member uses the conventional SBC motor mounting pad.
My K-member uses the multi engine mounting geometry.
If I remember correctly, your pad recieves the factory (or moroso) style mounts. Mine uses AJE's mounts that can recieve SBC, BBC, and LS1.
That being said, AJE seems to do good fabricating work. Just give Jim a call, he should be able to accomidate you.
Car: 1984 Trans Am
Axle/Gears: Stock
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Car: 89 Firebird Formula
Engine: 3500T
Axle/Gears: 9 bolt/4.11
I have spohn coilovers on my car and I've done 30,000 kms of street driving without any noticeable damage. However I also have a rust-free hardtop. I am planning on stitch welding the strut towers before I put it back on the road though.
I should add that the spohn coilovers limit the amount of possible camber adjustment, but other brands don't have this limitation because the mount the spring underneath instead of inside of the strut mounts.
anyone considering this modification on a thirdgen i would highly advise against it for anything other than a straight line drag/street car and/or trailer queen. The weight savings are minimal and the ride quality is substantially altered.
Engine: 3500T
Hmm I have spohn coil-overs with stiff springs and Tokico struts and I find the handling quite well. It's definitely not a drag racing setup. Makes for a stiff ride but I like it personally and am not a fan of soft suspension.
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Engine: 3500T
I'm planning on stitch welding my strut towers but if I think your much more likely to have problems if your strut towers aren't 100% rust free. I think that's where any problems would be
darwinprice
17
Oct 11, 2015 11:51 PM
tmork454
Sep 29, 2015 06:33 PM
