1 vs 2" drop
Old Apr 11, 2011 | 09:55 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
1 vs 2" drop
Debating on which I should go with. I'll be putting 17" wheels with 40 profile so I'm lookng to drop my car. Front Spindle then Rear Spring. So I'm trying to figure a good combination. Also trying to watch out for being to low and hitting things. So i'm curious on what others have done. Also If you could give me your front spindle and rear spring specs.
Thanks!
Old Apr 11, 2011 | 11:25 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: 1 vs 2" drop
I went with 1" intrax springs all around. Im happy. My car rides pretty smoothe. Exhaust scrapes quite a bit though
Old Apr 12, 2011 | 01:10 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: 1 vs 2" drop
Never heard of 1" drop spindles.. I know of 2" racecraft spindles, which might be a bit much though.. Also, 17 inch wheels with 40 profile are too low profile, usually 17 inch wheels have 45 profile tires to maintain stock tire height.
Old Apr 12, 2011 | 08:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 1 vs 2" drop
a real 2" drop is way to much for any car that isnt only driving on a perfectly flat surface.
1" is about right.
Old Apr 12, 2011 | 09:40 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Re: 1 vs 2" drop
I went with Racecraft 2" and swivel cup weight jacks in order to adjust. In back, I went with Spohn's QA1 coilover set-up with 200# springs. Did this over the winter, alignment is a week from tomorrow . Firestone Wide Oval's going on at the same time (245/50/16).
Love the stance, waiting to see how it performs.
Old Apr 12, 2011 | 09:49 PM
Re: 1 vs 2" drop
any pics of the 2" drop?
Old Apr 12, 2011 | 10:06 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Re: 1 vs 2" drop
https://www.thirdgen.org/forums/susp...g-vetruck.html
Post #25
I'm starting with a conservative 26.5" in Front, & 27.5" in back. I'll go lower, but I'm also planning a trip to Memphis --> New Orleans - Beale St, Hwy 61 into Mississippi for a Blues tour; then Natchez Trail Parkway for sightseeing; and New Orleans for food.
That will leave only those states North of Yankee stadium left (A New England trip)-- I will have driven my car in all the lower 48!
Old Apr 13, 2011 | 09:26 AM
Re: 1 vs 2" drop
Thats not bad actually.. You don't have ground FX so you shouldn't be scraping like all the iroc and gta ground fx do lol.. In that pic you are at 26" in the front, correct?
Old Apr 13, 2011 | 07:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: 1 vs 2" drop
Post #25
that the exact height my 92 is sitting at, front and rear. I feel its about perfect. Im using through the frame weight jacks front and rear, and tall ball joints.
even have the exact same tires
Old Apr 17, 2011 | 09:36 PM
nalls426's Avatar
Car: 1991 Rs Camaro
Engine: 5.3l h/c/i
Transmission: t56
Re: 1 vs 2" drop
just run spotlines! i have factory tires and wheels on there right now and i have no clearence issues at all! and they ride great with 5 way adjustable tokico shocks and struts
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
