MOOG 5662 Front Springs with a full coil cut (stance and clearance referance pics)
Old May 18, 2012 | 10:09 AM
  #51
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: MOOG 5662 Front Springs with a full coil cut (stance and clearance referance pics
Moog's own specs say the 5662s are 748 pounds per inch. Wire diameter is 0.750", and the intended static load is 1690#. The 5664s have a 0.765" wire dia., a 707 PPI rate and an 1863# ISL. http://www.moog-suspension-parts.com...il_Springs.asp
Old May 18, 2012 | 02:06 PM
  #52
made2drag's Avatar
Car: 88 ta
Engine: tpi 305
Originally Posted by made2drag
so you cut 1 and half coils on a moog 5662 spring and it gave you 3 inches.....cool!
im either going to do that or modify my lca's....here's a thread i started...im still wondering if it would work...i would also trim my upper spring pocket openings and flatten my lca humps to gain more travel. i want to be 2 inches off the ground and relocate my exhaust up or modify the exhaust to gain more clearance. i cant drive my bird this high too much longer...haha
oops, forgot to put the link on there...
here it is: https://www.thirdgen.org/forums/susp...er-spring.html
Old May 18, 2012 | 02:33 PM
  #53
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
I did the 5662's last year with a full steering rebuild, new bushings and ball joins and mine has maybe settled an inch, i got my air shocks pumped just so it doesn't look stupid high in the front and nice and settled in the back. that and I live in upstate ny on back rds so a little bit of lift works perfectly, but i wish the stupid things would settle.
Old May 18, 2012 | 03:34 PM
  #54
made2drag's Avatar
Car: 88 ta
Engine: tpi 305
hey man, can you please post a pic or 2 of how your car sits and how may coils you cut front and rear? how much ground clearance?
Old May 18, 2012 | 04:11 PM
  #55
84redta's Avatar
i didn't cut any coils yet...i may in the future. if i had to guess, i would say I have like 3 inches of clearance wheel to fender lip. I then went ahead and pumped up my rear shocks to match so that there was still a downward rake and it didn't look like I was trying to take off as I drove down the road. I will see if I can get home from work in time to get some day time pics.
Old May 18, 2012 | 04:39 PM
  #56
made2drag's Avatar
Car: 88 ta
Engine: tpi 305
Originally Posted by itsMikey
cut half a coil more off
yessir
dude you need these wheels...i wish they made them in our lug pattern
http://forums.thecarlounge.com/showt...zero-good-deal!!
Old May 18, 2012 | 04:44 PM
  #57
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
ughh those are dope..remind of the enkei 92's
the 5662's are 749 spring rate..mine are probably at 800+ now..i clock my bumpstops daily so im gonna be trimming them soon
Old May 18, 2012 | 04:53 PM
  #58
made2drag's Avatar
Car: 88 ta
Engine: tpi 305
sweet, i wish i had more pics of your 3 inch drop. i'll be doing mine in june.
Old May 18, 2012 | 07:11 PM
  #59
itsMikey's Avatar
Engine: 5.7 350 TPI
me too gonna wash it up soon and take it out for a shoot
Old May 19, 2012 | 10:17 AM
  #60
made2drag's Avatar
Car: 88 ta
Engine: tpi 305
cant wait for pics
Old Jun 29, 2012 | 05:40 PM
  #61
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
what is the spring rate for the rear ? and you know what swaybars your running
Old Jun 30, 2012 | 02:15 AM
  #62
itsMikey's Avatar
Engine: 5.7 350 TPI
rear spring rate, i am unaware of..they are 4th gen rear BMR springs though
'stock huge *** GTA sway bars
  #63
itsMikey's Avatar
Engine: 5.7 350 TPI
and i sent this to zach but heres this for referance..
stock
uncut moogs
i cut a coil off and got this:
coil and a half got this:
Old Jul 2, 2012 | 12:05 PM
  #64
Engine: 305 to 350
Axle/Gears: 10 Bolt
yea i had to cut my bumpstops already i cut a inch off noticed car was abit smoother on bumpy roads but still clock the bump stops here and there but not as much lol thanks for the pics for reference
also is it a pretty stiff ride ? or not noticeable
Old Jul 2, 2012 | 08:46 PM
  #65
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Be sure to taper the bump stops similar to the original pointed shape, otherwise they will hit harshly & can cause a sudden understeer (front bump stops), or oversteer (rear bump stops) while in a turn.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
TheExaminer
Aug 25, 2015 07:34 PM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
TA8487
Aug 11, 2015 09:02 PM
