MOOG 5662 Front Springs with a full coil cut (stance and clearance referance pics)
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
i cut a full coil off the fron 5665 springs and the rears are BMR 4th gen lowering springs
3" Exhaust
added:
stock
uncut moogs
i cut a coil off and got this:
coil and a half got this:
if you guys want anymore pics..lemme know
Mikey
3" Exhaust
added:
stock
uncut moogs
Mikey
Engine: 5.7 350 TPI
Re: MOOG 5665 Front Springs with a full coil cut (stance and clearance referance pics
fender gap
then just an extra pic that i took
Engine: 5.7 350 TPI
thanks bro
haha..
haha.. Senior Member
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
no prob i want a gta soo bad. i know theres a shop here in town with a guy tryin to sell it. but i cant buy it i got enough on my hands with my car lol you know how it is
Car: 1991 Trans Am
Engine: L31, LT4 hot cam
Axle/Gears: 3:42 LSD
looks good - seems a wise compromise between looks and streetability - some 'out-in-the-open' pics would be cool to get a better idea of the stance
a quick note I cut full coil off of some '92 WS6 springs and added the rear spring rubber mount thing and I'd say my front end sits bout an inch lower (by wheel-arch gap) then yours
interesting...
interesting...
Engine: 5.7 350 TPI
these are 756 pound springs though...wheras the ws6 springs are about 500 pound IIRC.
they arent comfortable by any means but i have near NO body roll..once i get the SFC's in, im assuming almost zero body roll..we'll see tho
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Not to be a stickler, but 5665 springs are rear springs (107 lbs)
You either have the 5662 or 5664 springs. It's an honest mistake.
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
What are the heights from center of fender to ground for all 4 wheels?
I love the pics, very detailed and really shows the lower parts of the car and how close they are to the ground.
Engine: 5.7 350 TPI
there the 5662's!!and thanks
took these specifically for that purpose..just hoping to help a couple people out in the desicion on springs..there great springs for auto-x...but like i said..you feel EVERYTHING.. Joined: Aug 1999
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
That's what I was aware of as well, they are VERY stiff and as he said there is pretty much zero body roll in corners, and I am 2" higher than most people on this forum lol.
Another thing to consider is that since he cut a coil, that should raise the spring rate, no?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
yes it does, depending on how much was cut off, and how the coil was formed where he cut it. the first coil is usually a lot shorter than the rest because its flattened out to fit int he a-arm.
Car: 1988 Firebird Formula
Engine: 5.7 TPI
Axle/Gears: 3.27 posi 9 bolt
Re: MOOG 5662 Front Springs with a full coil cut (stance and clearance referance pics
hmm, I cut about 1/2 coil from mine and I have about 1.5" from the bump stop - a-arms a parallel with the ground. Very stiff on the road and almost too stiff on bumps that cause it to bottom. I run 25lbs in the tires and that makes it ok and at least I don't spill my coffee in the am anymore lol
Engine: 5.7 TPI
Pics are great BTW, car looks very sweet.
Engine: 5.7 350 TPI
ive spoken to the owner and he has confirmed that they are 756. just hasnt been changed on the site
not if you cut the full coil off..then u can just set it in place and get it up with a jack...but i guess if u wanted to, you could. just to be safe.
doesnt raise the spring rate...doesnt change the coils. all your doing when you cut is shortening the coil length. confusing really..just changes travel i think. Vetruck can explain it better.
its flat but you can just cut a peice away after the full coil to make it flat.
thanks and thanks
thanks and thanks
Car: 1983 Z28
I cut 1/2 coil off my 5662's and needed a compressor. I was wondering if cutting off a full coil would eliminate the need for a compressor, that's all.
Found the answer, thanks Mikey.
What owner? Spohn? If so, that reminds me of the inconsistency (my bad). Note the following from 2007:
FYI: Spohn's IROC style springs have a rate of 748 and 107 (5662 and 5665). A correction has been posted on his site.
Here's the post in its entirety:
https://www.thirdgen.org/forums/susp...ring-rate.html
JamesC
JamesC
Engine: 5.7 350 TPI
i was told they are 756...even so..if they're only 706...there stiff..thats all i wanted..dont know much about the spring pound thing but i dont see 50 pounds doing much difference...
they did what i wanted...
heres what they did at full length (before i cut the full coil) -__- can you say 4x4???
drove it like that for a week just hoping i didnt have to take em out and they'd settle 8 inches
JamesC
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
i took a full coil off my 5662's.. and my car is dumped compared to yours..
My front sits pretty low compared to that (28.5 inches driver side and 28 inches passenger side from center of fender to ground) and I have not cut any coils.
JamesC
Engine: 5.7 350 TPI
well damn..maybe mine arent indexed correctly? should it be even lower?? lol
I've done tons of weight reduction on the front of my car, plus the fact i have 4th gen isolators up front and out back. Plus doing a battery relocation this week so that should raise the front even more lol..
The indexing part is interesting because I have UMI a-arms, which don't have a spring index I believe... I'll have to double check though.
JamesC
Engine: 5.7 350 TPI
ill jack it up later and take a look at it..because if it it could be lower id like that because right now the back is lower than the front....
For optimal handling the back should be level or higher than the front, not lower.
There are two holes in the a-arm. The spring end should cover one but not both.
EDIT: The holes are shown in post #5 of the link to follow:
https://www.thirdgen.org/forums/susp...nsion-how.html
JamesC
JamesC
Engine: 5.7 350 TPI
JamesC
JamesC
Engine: 5.7 350 TPI
there indexed 180 degrees backwards -__- ugh...how can i just turn em without taking them out?
Car: 1989 Mystery Firebird
Engine: 350 FIRST TPI
i gotta cut mine cause mine looks like im going off road
Engine: 5.7 350 TPI
yeah mine do too now...again...
i put em how you guys said...
end of the spring covering one of the holes and it sits higher now...
soooooo wtf? lol..
soooooo wtf? lol..
Engine: 5.7 350 TPI
heres how it sits now...
where i put the end of the spring...
and if the picture isnt clear...i put it
Have you driven the car yet? If not, drive it around the block and see what happens.
JamesC
JamesC
That looks somewhat right.. But give it time to settle, might even take 2 weeks to settle..
Engine: 5.7 350 TPI
drove it around the block...it doesnt take 2 weeks to settle...it takes, backing out of the driveway and pulling forward.
they arent progressive springs..
im gonna take em out again today and turn the spring more i think..
Engine: 5.7 350 TPI
and even with progressive springs, its not gonna sink 6-8 inches...
In my experience, they settled quite a bit over the course of 2 weeks.. The car was really jacked up when I first got it but then it came back down quite a bit, but not 6 inches though, maybe 1 inch, hard to tell as I did not measure really..
The 'settling' issue has always intrigued me. People speak about it, but my springs didn't 'settle' a fraction of an inch from summer to summer.
JamesC
JamesC
Same.. I'm sure that weight might have a play in it? Or it could be because I installed the 4th gen isolators, maybe those eventually became more compressed over time? Not sure really.. I'm glad my front went down a bit, now I just have to cut the springs a tad in the rear to match.
Engine: 5.7 350 TPI
i put em back in the way i had em before...
sits like it did..
i think its not sitting how its supposed to because they were cut..
sits like it did..
Car: 88 ta
Engine: tpi 305
ok, so this thread is really old, but what happened next? i need to know how your car is so low and how you got it lower after this thread left off? thanks, i need to lower mine really soon
Car: 1992 Z28 Heritage Edition
Dumb question but, what is the red bar called running across the engine bay?
Car: 88 Iroc Z, 00 SS
Engine: 5.7 HSR, 5.7 LS1
Transmission: 700r4, T56
Axle/Gears: 3.23, 3.42
its a strut tower brace
Engine: 5.7 350 TPI
yessir
Car: 88 ta
Engine: tpi 305
so you cut 1 and half coils on a moog 5662 spring and it gave you 3 inches.....cool!
im either going to do that or modify my lca's....here's a thread i started...im still wondering if it would work...i would also trim my upper spring pocket openings and flatten my lca humps to gain more travel. i want to be 2 inches off the ground and relocate my exhaust up or modify the exhaust to gain more clearance. i cant drive my bird this high too much longer...haha
