Spohn front end rebuild kit thread failure.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 87' IROC
I did a complete suspension, brake, and steering rebuild last year. I choose the Spohn front end rebuild kit. Installation went fine.
Fast forward to today and about 1000 miles later.
I had to remove my centerlink in order to install a new oil pan. When I went to reinstall the centerlink, one of the inner tie rod studs and then one of the centerlink studs stripped out before reaching the GM spec torque of 35 ft-lb. This is only the second time the castle nuts had been tightened.
I am a religious torque wrench user and have no reason to believe my torque wrench is out of spec.
At this time I cannot recommend the Spohn front end rebuild kit and all of my steering linkage will be replaced with MOOG components.
John
John
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Spohn front end rebuild kit thread failure.
Have you tried contacting Spohn about it? Steve use to be very good at customer support/service.
Car: 87' IROC
I do agree, Spohn has good customer service. I have purchased thousands of dollars of parts from them and they have always been good to me.
I always wondered , what kind of warrenty do Spohn parts have compared to say Moog or TRW.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
im sure Spohn doesnt forge their own steering parts. they are just relabeled parts.
FWIW, sombody else had a PST setup fail too recently.
wonder who spohn uses?
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
I used a Spohn kits several years ago now and at that time it was all Moog parts, just sold as a kit.
1 Post
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I used Spohns bolts for a rebuild on attaching the strut to spindle. 3 of the 4 failed and stripped before reaching GM's tq spec. I reused stock 90K bolts with no problem.
Car: 87' IROC
No doubt. They may use different moving parts though. The grease cap does say Spohn on it, so at a minimum they were at least goofed with at some point.
Car: 87' IROC
They are not reboxed Moog parts. They have a very different coating as well. They have a very nice Zinc plating while the stock Moogs are painted. They may be Moog's but they have had some work done on them.
Car: 87' IROC
We aren't talking about spindle botls. We are talking about front end rebuild kits. However I have used Spohn's spindle bolts with no issue.
Car: 87' IROC
Ok here are a bunch of pictures showing the difference. Maybe someone can compare them to the PST parts. These are Spohn (silver) vs MOOG (black).
![](http://farm6.static.flickr.com/5261/5892724835_cfba66b5e3_b.jpg)
![](http://farm6.static.flickr.com/5279/5893292592_27be247cda_b.jpg)
![](http://farm6.static.flickr.com/5068/5892725175_f761b81980_b.jpg)
![](http://farm6.static.flickr.com/5313/5892725347_2bddd2de71_b.jpg)
![](http://farm6.static.flickr.com/5312/5892725517_3613bedd2a_b.jpg)
hectre13
12-11-2023 08:14 AM
Terrell351
06-13-2021 01:13 PM
