UMI SFC, Torque arm and Panhard Bar install in Super Chevy
I wanted to share the recent technical article from Super Chevy showing a few items from UMI being installed including our weld in SFC's, chassis mounted torque arm and adjustable panhard bar. In case you didn't see it in the magazine below is the link.
http://www.superchevy.com/technical/...ion/index.html
Thanks for looking!
Ryan
Thanks for looking!
Ryan
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: UMI SFC, Torque arm and Panhard Bar install in Super Chevy
ahh there he is. Havent seen you here in a while, though you forgot about us, like that *cough cough*t-shirtinevergot*cough cough"
congratulations on the write up! I did miss that article before.
I did forgot all about that shirt! I will get it taken care of... just had a new batch come in Monday!
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
looks good ive been wanting to purchase the sfc's since all my suspension is umi.. but by the looks of it i thing the drivers side would interfere with my exhaust.
any updates on the front a-arms?
We just added the bump stop and spring index to the A-Arms. We are also redesigning the entire arm (for a new look) and the arm will also include a bump stop, spring index and steering stop.
Thank you,
Ryan
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
Usually the passenger side is the exhaust issue side and drivers side is clear. What exhaust are you running?
Thank you,
Ryan
Thank you,
Ryan
as for the a arms i will be taking down my k member soon. i will pm you sometime soon regarding my past purchase on the a arms.
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Ahh crap, I just ordered a set yesterday. lol. Hopefully mine come with the bump stop and index lol.
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
Thank you,
Ryan
Thank you,
Ryan
EDIT********
If I did go ahead and replace my factory stamped Torque Arm with your unit as shown in the article, do you have a setup for a T56 trans in a third gen? I might be interested in doing that Torque arm relocation in the future to stiffen up the car if I can get it setup to use with a T56. I know Spohn has torque arm relocations that incorporate the T56 trans, just wondering if you guys did too. Spohn is the only place I've seen the T56 trans crossmember for third gens. 2216-B is the part number I have been looking at, as I don't care for the driveshaft loop, but since I'm putting a T56 in it sort of doesn't apply.
Right now all A-Arms will ship with a bump stop and spring index, this is our same arms seen now with these added items. In 2-3 weeks we have a newly designed arm coming out... basically changing the look while adding in the bump stops and indexes. These arms are on a car now and alignment is being sorted out.
At this time no T56 crossmember but we will have one shortly.
Thanks!
Ryan
I have to ask, but what is the appeal of bright red stuff under an otherwise not clean/rusty and most of all not red underside????
Car: Too many cars
Car: 86 Trans Am
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
I like that UMI PHB design better than the UMI PHB design I bought. It can be more easily adjusted. With mine, one end had to be "uninstalled" from the car to get the wrench to fit the lock nut. The lock nut is right inside the chassis side mount so a wrench doesn't fit.
I can't really afford to sell it just the buy a different design, so I just deal with it. Just wish it hadn't even existed in the first place, or that the lock nut on that side was further out somehow.
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
i have all black suspension aftermarket parts... it looks more factory and doesnt stick out like a sore thumb... my undercarriage is still all black with the factory coating... no rust anywhere... i dont like the red version parts.... just looks to flashy for me..
Engine: gone
Transmission: gone
Axle/Gears: gone
I run red on my red car daily driver. I have red LCA and brackets in back. With a black panhard bar cause that is edelbrock (great deal on it). Then I went with black subframe connectors because I didnt really want them sticking out all that much. But I got a red transmission crossmember/torque arm relocation kit. and a red wonderbar. I like the red. But I udnerstand what y'all are saying. mine is a daily driver too. ANytime i have it up in the air I give the suspension a rub down to clean up the parts.
Car: Formula
Engine: 6.0 LSX
Non daily driver here. I have all red, but black subframe connectors.
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Axle/Gears: Moser 9" 3.70 Wavetrac
I run red because my GTA is maroon, I think it's justified. I like the flash the red pc gives off. Pure preference!
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Hi Ryan,
Good news about the spring indexes and the bump stops. GLad to hear you guys are listening to your customers on here
Will the bump stop be made available as an add-on for people like me who already have the original version?
Thanks,
-Marc
Thanks,
-Marc
Car: 86 Trans Am
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
Car: Formula
Engine: 6.0 LSX
Got the UMI arms with the spring indexes and bump stops. Looks Nice! Let me know if you guys want pics.
Please!
I've got the UMI SFCs, LCA and relo brackets, panhard, and trans mount torque arm. great stuff.
I like the red.
I like the red.
Well that's more like it. This is how mine should have came. I like the fact that UMI is correcting/updating their design, it shows they are listening!
Also, I wonder if they will make a-arms with a design similar to SPOHN's del-sphere adjustable version? I think UMI has the roto-joint type bushings?
How's the fitment with these and the stock k-member? Maybe they should finally come out with a 3rdgen k-member for us LSX swap guys
The fitment is good. I have not had issues. (there were problems that i've posted in the past but found out they were unrelated to these a-arms)
Car: Formula
Engine: 6.0 LSX
Fitment is good here too with Spohn's Tubular X member. So far.....
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Hey UMI. Are you guys going to have a crossmember (with torque arm relocation) for a T-56 transmission in a third gen? Just wondering.
I didn't find one of these in your catalog.
