New Front Lower A-Frame Bolts
Old Jun 2, 2011 | 02:36 PM
djmarch's Avatar
Car: 1989 GTA - Gunmetal grey
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
Anybody know where one can pick up a set of new front lower a-frame bolts ?
Can't seem to find any on the web. Mine will be destroyed by the time I pull my lower a-frames off to replace the bushings.
Old Jun 2, 2011 | 03:22 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Re: New Front Lower A-Frame Bolts
Dealership. Or pull some out at the junk yard.
Old Jun 2, 2011 | 03:37 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
http://www.spohn.net/shop/1982-1992-...dware-Kit.html
Good luck on the removal. Some, if not all, of the bolts will be frozen to the sleeves--unless you're darned lucky. I'd use a bit of anti-seize on the new bolts.
JamesC
Old Jun 2, 2011 | 04:59 PM
Demon355's Avatar
I got mine at Brafasco. Just brought one of the stock bolts with me.
Old Jun 2, 2011 | 07:41 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
they can be replaced with 12mm grade 10.9 bolts, just measure and order, or buy locally, or use Spohns kit. I have a set from UMI that im not using, but they are a bit on the long side.
Old Jun 2, 2011 | 10:06 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I have a a bunch of stock sets of the nuts and bolts you seek.
Old Jun 3, 2011 | 08:20 PM
djmarch's Avatar
Engine: 5.7 ltr.
JamesC
Yea I know....That's why I replacing them as well..
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
Street Lethal
Aug 14, 2015 08:25 PM
