converting ps box to manual box?? need help
Car: 1992 chevy camaro
Engine: 5.0 TBI
Axle/Gears: 3:73 n 4th gen rear
i wanna change my power steering box to a manual steering box becuase i dont wanna run ps pump so i can only have 1 belt on my motor to the altonator only. but any way i cant seem to find any that are a good price and not alot of money. ive looked on summit, and jegs.com and they are about 599.99
so i was wondering if maybe someone has done this conversion and can tell me if i can use another steering box out of maybe another vechile or what id have to change around to be able to make it work. thanks
Car: 1983 camaro with88nose ground effec
Engine: 468bb
Transmission: 700r
Axle/Gears: 323 posi
Re: converting ps box to manual box?? need help
how about s10 box you just change pitman arms install and you can find on ebay cheap somtimes on third gen
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
Mine still has the power box but no pump, I just looped a line from port to port on the box. I am in no way recommending this but I have done this on 3 cars now and this car is the easiest to turn without the pump and it will work until I find a manual box from a S-10 pick up. Good luck.
Mark.
Mark.
Engine: 5.0 TBI
so just get the s10 steering box and pitman arm. if thats the case ill just get one from a jumkyard or from my local auto parts store.
Engine: 5.0 TBI
any year s10 or like 88 same year as my car??
oh and thanks alot
oh and thanks alot
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
84+ S10's. The box with 4 bolts on the top cover. Only S10's with the 2.5L 4 cylinder engine came with manual steering boxes but not all 2.5L S10's had manual steering.
The earlier boxes with a 3 bolt top cover will work but they're not a direct swap so I don't recommend them to someone who doesn't know how to properly convert it. The later boxes are a direct replacement for the power box. Steering shaft, pitman arm etc all bot right up. You can keep the S10 pitman arm but it's a slightly different length and will change the steering geometry slightly. Using the F-body pitman arm is a better choice but you're going to need a puller to swap it.
Looping the lines on a power steering box doesn't really make it a manual steering box. All you've done is eliminated the power assist. The power box does not have the same steering ratio that a manual box has so without power assist, it's harder to turn the wheels.
If the local junkyard didn't keep raising the cost and fees for all the parts, I'd still be pulling them and selling the manual steering boxes on Ebay. I can't get one from the junkyard for less than $50 now. I used to be able to get them for $20 then sell them on Ebay for a good profit. Taxes, environmental fees, core charges have all added up plus the base cost has gone up. Add in the much higher Canadian dollar and shipping across the border has become very expensive so I can't compete with American sellers any more.
Car: 84 Camaro
Engine: 357
Transmission: TH350
AlkyIROC: Looping the lines on a power steering box doesn't really make it a manual steering box. All you've done is eliminated the power assist. The power box does not have the same steering ratio that a manual box has so without power assist, it's harder to turn the wheels.
If this was intended for me, I know it doesn't make it a manual box, It is much harder to turn like this and not the "right" way to do it, but it gets me by for now. So are you saying that all I would have to do is get the manual 84+ 4 cly box and put my pitman arm on it? Thanks.
Mark.
Mark.
Car: Working on an 85 Camaro.
Engine: Hopefully 383 Stroker
Transmission: Will be a Power Glide
Axle/Gears: Undecided, thinking 411's maybe?
whatever84- that is correct. Find a manual box from an 84+ s10 and just swap it out. Easy as 1, 2, 4. But like Alky said, you will need a pully puller to get the pitman arm off. Good Luck! Its a pretty easy swap though.
Car: 84 Camaro
Engine: 357
Transmission: TH350
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
backtothe80s
Sep 5, 2015 12:39 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
