gabriel high jackers shock/strut
Car: 91 Camaro Z28
Transmission: auto
Does anybody have these on their third gen? or another brand similar to these. If so any pictures to see how it will look with a raised rear end stance?
http://www.autozone.com/autozone/par...8_116379_6636_
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: gabriel high jackers shock/strut
oh, people here have them, they are a bad idea. the sir shock puts the weight of the car on the stock upper shock mount, which is really not designed for that continuous loading, and it will eventually fail.
if you want to raise the back of the car, there are better (if its ever better) ways of doing this.
It's not the 60s anymore.
If it's just sagging some, just change out the springs. They're cheeeeeeeeeeper BY FAR than air shocks. Use Moog 5665 if you prefer constant-rate or CC635 for variable-rate.
The suspension geometry of these cars does not take kindly to being disturbed too far.
Car: 91 Camaro Z28
Transmission: auto
It doesn't sag, I just wanted them for the look
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
If your just looking for a slight rake you could try something like this from "Summit Racing" =
SPC Performance 1628 - SPC Performance Coil Spring Spacers
View Image and CompareCoil Spring Spacer, Aluminum, 1.50 in. Thick, Rear, Natural, GM, 22.99 Each
Part Number: SPS-1628 More Detail …
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
A pair of fourthgen spring isolators will also jack the rear up an inch of so.
JamesC
JamesC
camaro, car, coil, gabriel, gabrielhighjackers, gen, high, highjackers, jackers, jackersshockstrut, performance, rear, spacers, spc, spring, strut
