Del-A-Lum Bushing Install Problem?
Car: 86 IROC-Z
Engine: 370 LQ9
Transmission: T56 Magnum
I pressed out the old bushings. Went to install the Del A Lum bushing, and it seems no where close to even fitting in the a arm. I pressed the other side out and the same thing; wont fit. I centered the bushing as best I could since Ive heard its a tight fit, and it was a no go. The brace shot out, and the bushing received some damage.
A-arms are the stock ones off my 86 Iroc. I'll get some pics tomorrow.
EDIT:
Im guessing the metal sleeve needs to come out???
EDIT:
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Re: Del-A-Lum Bushing Install Problem?
When I put the poly bushings in my A-arms I could have done them myself as I do have a press but I decided to send them to someone who was recommended to me. When I picked them up he said they were an absolute bear, I can only imagine what del-a-lum bushings are like.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Car: '89 GTA
Engine: 5.7L LS1
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Yes you have to remove the entire factory bushing & exterior shell.
They press in from the outside.
Install the outer blue shell, then press the inner sleeve inside the delrin bushing, lube, then push inside the outer shell.
Car: 86 IROC-Z
Engine: 370 LQ9
Worked on removing the shells and they were a pain at first. The hardest part was figuring out a technique to remove them, after that it wasn't too bad. Once I get the bushing installed, I'll post a step by step on the whole procedure with pics.
Hopefully these things are worth it.
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
One of the absolute best upgrade I ever did to my car! Period!, and I have alot of upgrades. I get asked all the time how my car stays so flat through the corners at the road course and autocross. If you have ever scene a stock or close to stock thirdgen autocross they kind of thrash around pretty good (pitching and rolling). I have other mods but these seriously got me 60% of the way to a decent handling car.
Car: 86 IROC-Z
Engine: 370 LQ9
Never wrote a step by step, but heres a break down of what I did.
Start off by removing the rubber bushings from the shells. I simply drilled multiple holes through the rubber, until it basically all feel out.
To remove the metal shells, I used two different techniques. For the larger shells I was able to find a socket that fit perfect over the shells edge. I just hammered those out, with a 8 lb sledge hammer. I used the angle iron supplied with the del-a-lum bushings to keep from hammering the frames of the a-arm together.
The smaller shells were a pain, and took the most time. I started off by using a sawzall to cut them in half. Then I hammered various chisels between the two cut half’s. Use the vise grips to twist and turn the shell once theres enough material to grab onto. I used a c clamp to keep the frame of the a-arm from spreading too much. Only one of the half’s would start moving out, so I cut the remaining shell flush on the inside or as close as I could. Then used a flat head screwdriver and carefully hammered it out. Again using the vise grips once there was enough to grab onto.
After I was done I ended up finding a thread that explained how to remove the smaller shells a different way. It involved using a dremel, and cutting slits on the shells lip I think. Heres the link: https://www.thirdgen.org/forums/post...23-post12.html
Tools used:
Drilled out rubber bushing:
Socket:
Sawzall shell:
Hammering out the other side:
All out:
Tools used:
Socket:
Sawzall shell:
All out:
Car: 86 IROC-Z
Engine: 370 LQ9
I dont have any pics of installing the del-a-lums, and for some reason have no recollection of how I pressed them in. All I remember is to make sure to point the grease fitting at an angle you can get at when the a-arms are installed on the car, before you press them in. Double and triple check.
Car is still down unfortunately, its getting close though. Everything suspension wise has been upgraded at the same time along with the ls1 swap.
Sweet. I cait wait to get this thing on a road course/autocross.
One of the absolute best upgrade I ever did to my car! Period!, and I have alot of upgrades. Igett asked all the tim how my car stays so flt through the corners at the road course and autocross. If you have everscene a stock or close to stock thirdgen autocross they kind of thrash around pretty good (pitching and rolling). I have other mods but these seriously got my 60% of the way to a decent handling car.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
NBrehm
Aug 5, 2015 07:57 PM
