Drum to disk
Old Oct 1, 2011 | 03:54 PM
1987_sportcoupe's Avatar
Car: 1987 Sport Coupe
Engine: Carbeurated 5.7
Transmission: NWC T-5
Axle/Gears: Non-posi 2.73
Drum to disk
So i want to swap out my 2:73 drum rear for a 3:42 disk rear. I was wondering what all would I have to swap with the rear end? Thanks
Old Oct 2, 2011 | 12:36 PM
83 Crossfire TA's Avatar
Re: Drum to disk
the rear will bolt in, but to get things to work right you'll have to swap in a disk MC and combo valve (rear disks require more fluid flow and line pressure) and depending on the year/model (pontiac and chevy changed at different times), you'll need to swap the speedo gear/breakout box to get the speedometer to read right.
Old Oct 2, 2011 | 02:08 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Drum to disk
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
6speedIROC
16
Mar 15, 2023 08:33 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
92projectcamaro
Dec 8, 2015 12:25 AM
dbrochard
Sep 25, 2015 04:56 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
