Are you using a BMR K member, BMR lower A-arms and coil over conversion kits
Old Oct 9, 2011 | 09:57 AM
overdriv's Avatar
I have a 87 Camaro that I am building for a race car. I have installed a BMR K-member, BMR Lower control arms, BMR coil over conversion kits. Stock Spindles.
The problem is, There is not enough adjustment in the camber adjustment slots to properly adjust the camber.
These cars are enough alike that I just can't imagine someone else not running into this problem before.
Repeated attempts to get help from BMR go unanswered.
Old Oct 9, 2011 | 04:33 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: Are you using a BMR K member, BMR lower A-arms and coil over conversion kits
I've never actually looked to check for slots, but assuming ours are like most modified macpherson strut suspensions, then our strut towers aren't slotted for adjustment, the alignment for camber is done where the strut bolts to the spindle, unless you get camber adjustment plates, you really aren't going to get much camber out of it, regardless of your suspension components being factory or aftermarket.
Old Oct 9, 2011 | 05:11 PM
overdriv's Avatar
My 87 Camaro has adjustment slots (from the factory) on the brackets that hold the top of the strut/shock. The BMR Coil over conversion kits provide an upper spring cup that installs under the factory brackets. These upper spring cups share the bolts that hold the top plates on. The BMR provided plate is slotted to match the factory plate.
The adjustments you mention, where the strut attaches to the spindle are to adjust caster I think. I don't see much camber adjustment to be had there.
Old Oct 9, 2011 | 05:32 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
not enough in the BMR slots or the factory slots?
nope, no real adjustment in the spindle bolts, unless you use aftermarket ones. The towers are slotted for caster adjustment (front to back), and the strut mount is slotted for camber (side to side).
Im not familiar with how BMR mounts the spring, but it though it was to the underside of the tower with a different plate? I dont see how you could adjust much with that setup, and FWIW, spohns setup also doesn't allow much adjustment. How much camber do you have, and what are you trying to achieve?
The coilover setups for the front and generally more of a drag setup to reduce height.
Old Oct 9, 2011 | 05:53 PM
Engine: 3.8, 3.4
Hmm, didn't know that, but to be fair I'm learning this stuff on new cars :P
Surprised you went with coilovers on the front btw, generally advised against, mostly cause of the additional weight that has to move when you turn.
Old Oct 9, 2011 | 06:58 PM
overdriv's Avatar
http://www.bmrsuspension.com/index.c...&productid=352
This is what I have. Notice the slots. Those plates go under the OEM plate that has slots. The slots on my car are positioned cross wise of the car.
Now I wonder if I have something installed wrong???
Old Oct 9, 2011 | 08:49 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
An easy solution is to get some camber bolts for the strut to spindle mount. They generally can give you an additional 3* or so of camber adjustment.
Old Oct 9, 2011 | 09:08 PM
overdriv's Avatar
Can you give me a link to these bolts you mentioned or better yet point me to a picture of them. Thanks!
BTW, thanks to all who have replied, I appreciate it.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
lt1z350
Aug 28, 2015 05:57 AM
overdriv
Aug 20, 2015 03:52 PM
