using rod ends as outer tie rod ends
Old Dec 15, 2011 | 04:47 PM
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
Transmission: TKO-600
Is using a rod end in place of a stock style outer tie rod end a bad idea? I called QA1 and they said do not do it, camaro central.com said do not do it (couldn't provide any reasons why not to) and FK who manufacturers rod ends told me "I cant tell you what you can or cannot do" basically covering themselves for liability purposes but did go on to say that it is not an uncommon practice. Baer and other companies bump steer kits are rod ends... I do probably 10 road course races a summer, so it definitely sees some abuse. Any thoughts? (obviously i'd buy top of the line..stainless steel heat treated etc)
Old Dec 15, 2011 | 05:12 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: using rod ends as outer tie rod ends
Very common, however they are going to have a rough life, so they will wear out. I have them on both my cars and have had no issues at all, even on my 92 which I DD when its not snowing
Old Dec 15, 2011 | 05:28 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
My bump steer kit uses rod ends but also doesn't see the abuse of street use or road course racing. If you replace the rod ends every couple of years with a good quality rod end (not some cheap offshore part) then you should be fine.
Old Dec 16, 2011 | 08:46 PM
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
I appreciate the responses, i'll give it a go. 86, you have a picture of your set up? I was thinking i'd do a female rod end at the spindle and then run a length of threaded rod to the stock adjuster sleeve, using a jam nut to secure the rod at the rod end? It looks like there's a couple ways it could be done but wasn't sure which was best.
Old Dec 17, 2011 | 04:08 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
I just using heavy wall swadged tube and a male end. Eliminating the stock adjuster. I think the tube is 9" long. 5/8 18. Rod end is right hand thread. Then you wil need the proper tapered stud for.the stering arm connection.
Old Dec 17, 2011 | 04:17 PM
Twin_Turbo's Avatar
seals it seals + quality rod ends go a long way
Old Dec 17, 2011 | 05:27 PM
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
That had been my other thought. Thanks
Old Dec 17, 2011 | 05:33 PM
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
great, thanks
Old Dec 17, 2011 | 06:01 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
I have the Spohn bump steer kit and it works well even on the street and it turns much better when going over uneven roads and potholes.
Old Dec 19, 2011 | 08:56 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
I followed Twin_Turbo and 86TAs lead and put my own set together. Search for my name and I have a post out there with the list of parts needed to put it together. I have not finished putting my car back together, but I am assuming it will work just fine.
Old Dec 19, 2011 | 09:21 AM
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
Cool thanks
Ghettobird52
Apr 21, 2020 08:44 PM
Polo Z03
Wheels and Tires
49
Jul 21, 2017 12:31 AM
gixxer92
Sep 1, 2015 04:32 PM
zayne0
Aug 24, 2015 07:22 PM
