Delrin Bushing LCAs or Traction bars??
Old Dec 19, 2011 | 09:51 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
whats the best thing to get?? im so confused right now..
Old Dec 20, 2011 | 09:12 AM
UMI Sales's Avatar
Re: Delrin Bushing LCAs or Traction bars??
Hey Berlyn.
How's it going?
Are you interested in more traction for drag racing? Our solution is improved arms with relocation brackets to improve the instant center location.
http://www.umiperformance.com/catalo...dex&cPath=6_83
http://www.umiperformance.com/catalo...dex&cPath=6_85
Let me know how UMI can help you achieve your performance goals.
We have a Christmas sale coming up starting the 23rd...
Ho Ho Ho
ramey
Old Dec 20, 2011 | 12:56 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
What are you trying to do?
If you are having wheelhop issues, get a set of aftermarket rear lower control arms.
If you like to throw the car around turns, get some delrin bushings for the front control arms.
Really depends on what you car needs at the moment and how you use the car.
Old Dec 20, 2011 | 05:01 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
I wanna go fast!
it'll be a daily street car just wanna go fast off the line and have some good cornering too. so idk whats the best for that.
Old Dec 20, 2011 | 05:03 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
Originally Posted by UMI Sales
Hey Berlyn.
How's it going?
Ho Ho Ho
ramey
Already bought ur Polyurathane Front control arms 2031
their coming sometime or another whenever fedex gets here.
I was tryin to get the rear situated since all the bushings are parts are worn or damaged.
Old Dec 21, 2011 | 10:10 AM
3rdgenmaro's Avatar
Car: 88 IROC
Im sorry I thought you were talking about putting delrin bushings in the front control arms or buying a set of rear lower control arms.
Buy the rear lower control arms. Do not mess with any type of traction bar. Especially the Lakewood traction bars. They are a poor design. Get a set of UMI or founders lcas.
First thing I would recommend though is to do some reading on here and see what is recommended. SFC's, Lcarbs, etc....
Old Dec 21, 2011 | 10:16 AM
UMI Sales's Avatar
Hey Berlyn. Thanks for trusting UMI to your front suspension needs. We have 2031's on our in-house IROC and they have been abused without mercy for years. And are working great!
The rear arms and relocation brackets I linked earlier will help you off the line due to the bushing upgrade, actual material and design strength, and relocation bracket improvement. In the top hole, they work great for the twisties. In the bottom hole, you can launch great. Don't worry if you like the bottom for traction as your car will still work fine when cornering as compared to stock.
Good luck with your build.
ramey
Old Dec 21, 2011 | 06:04 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
R these the Relocation brackets?? Theres a red bar in place of the old control arm and then a smaller bar below it..
and if i got brackets should they be bolt in or weld in ? apppearantly they sell both.
is this setup meant for adjustable Rear trailing arms??
my heads spinning with all this stuff, theres too many options lol
oh and i think i might pass on the lakewood traction bars. i read other owners opinions and seems arent that great. some have been broken or weak welds.
Old Dec 21, 2011 | 06:22 PM
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
I wanna go fast! it'll be a daily street car just wanna go fast off the line and have some good cornering too. so idk whats the best for that.
Don't get LCARB's if you want to make turns well. You'll lose a ton of performance in corner entry but will have great acceleration on corner exit. This link sums up very well where you IC needs to be during breaking & acceleration:
http://www.unbalancedengineering.com/Camaro/TA/
Old Dec 21, 2011 | 06:39 PM
UMI Sales's Avatar
Good evening Berlyn.
Those are these: http://store.prestoliteperformance.c...y-1982-02.html
They do a similar situation as ours but have a bit different mechanism of action. I'm not too familiar with their adjustment but they've been around a long time so I'm sure they have some merit.
Adjustable lowers allow you to fine tune your rear end's location and make it perfectly perpendicular to the centerline of the car.
Our relocation brackets angle the trailing arms downward toward the rear whether they're adjustable or not.
Relocation brackets introduce roll steer on corner entry but don't necessarily hurt in all cases. If your car is tight on entry it can help the back end rotate.
ramey
Old Dec 22, 2011 | 10:51 AM
Berlyn0963's Avatar
Car: 91 Camaro RS
ya well im not buying lakewood if everyone says their weak. besides thier over 400 bucks.
Ed1LE
Sep 30, 2018 09:14 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
