Front LCA spherical bearings
Car: 1991 RS
Anyone know of someone making a spherical bearing kit for our front LCAs? I know Global West makes a kit for the 4th gens but I can't seem to find any for the 3rd gens.
In case your not sure what I'm talking about, here is a link to their 4th gen kit... http://www.globalwest.net/sp-7.html
UB Maching makes a solid bushing.. http://www.ubmachine.com/lowerbushings.html but that is still a bushing and not what I'm looking for.
And I can't seem to find any at Speedway Motors whom I thought carried something similar to the global west setup. GW just need to go ahead and make some for our cars!
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Front LCA spherical bearings
i don't know but i ckd. the globalwest site you posted . it seems the site lists them for 3rd gens . i ckd. 3 (three) times , each time i saw 3rd gen. . ??? re-check it yourself . good luck .
Car: 1991 RS
Could yall post some links? I just searched Founders and the only thing for our cars front suspension they have is Camber/Caster plates. And I have also searched GW's site and still don't see a listing for our cars for those spherical bearings. Maybe I'm blind but I don't see them.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Car: 86 Trans Am
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Global West # 1022
They're the Del-A-Lum bushings. Aluminum shaft encased in Delrin. No bind. Much faster turning response. These are the best that you can do with a 3rd gen.
Car: 92 RS
Engine: 94 LT1 383
Transmission: T56-6 Speed
Axle/Gears: posi, 3.26:1,
you mean Like this?
http://www.spohn.net/shop/1982-1992-...ing-Boxes.html
the globalwest site you posted says 93-02 , o.k. look at top of their page . say's 82-02 also , read the whole application . not a slam but read the whole page . good luck .
Car: 1991 RS
And the UB Machine stuff just looks like a solid bushing that will only allow up and down movement. And if the control arm mounts are not exactly aligned that could cause binding. They look a bit similar to the GW spherical bearings but I do believe they are just bushings. I guess if I cannot find anything I will just grab some of the UB stuff. I will give GW a call after xmas break to see if what they offer will actually fit a 3rd gen..
Car: 1991 RS
you mean Like this?
Car: 86 Trans Am
Right from Your UB link, this is a spherical bearing!
and even if you use a bearing vs a bushing, if the 2 mounts are misaligned, the bearing will be no different than a solid bushing, they will both bind. However, if the mounts are not aligned, the k-member is damaged and will need repair or replacement
ambainb
Apr 25, 2016 09:21 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
